The main power supply regulator section circuit fault. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Search the site by type in the "brand name" to your device; in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
if you can take the back off of it and use a soldering iron you can fix it yourself and save u money!!! just see where the connection came loose, heat it up and re-solder it
Sanyo CLT 2054 flickering problem is a power supply issue. You don't need to replace it if you can desolder, and solder. Break the case apart that is connected to the ac power cord. Remove the aluminum cover from the DC out end of the PCB. Unsolder, and replace capacitors C9 & C12 (1000mf 16v). Super glue the case back together, and watch TV. Good Luck...............Don't use cheap capacitors use caps that have a low ESR.
I need a power cord for a sanyo flat screen t.v. model # CLT 2054. My email as follows is [email protected] . Please let me know if you can be assistance in anyway. Thank you.
