Brother 130C notice : clean unable 46
i don't understand this notice . Plz help me
IT means you need to reset the purge counter in order to that .
For MFC - 240c
1.Enter mainatanace mode by pressing menu button at time of switch on. and leve the menu button when fax/scan/copy/photocapture button start blinking
2.press *, 8 & 0 and drag the this submenu by pressing mono button to get "purge" eg (purge:9624)
3.Press the 2, 7, 8, and 3 keys in this order to reset the purge count to zero.
4.Press the Stop/Exit . OFF the printer .and turn it on.
Due to manual cleaning procedures the ink absorber (waistinktank) is fed up. Needs replacement.
If you didnt run the ink cleaning procedure that much it would be a defective purge station (cleaning position). Needs replacement, too.
Same
I do notice the ink absorber tank is full. After replacing it, how do you reset the purge counters ( DCP-130C ) ?
SOURCE: clean unable 46 : what does it mean ?
...because you have run the cleaning cycles too much, the waist inktank is fed up! needs replacing. contact brother hotline or try to get one from a service partner which can be found on the brother homepage of your country.
thanks for this solution
Clean unable 46
hi after i pressed the menu after plugging it on. I pressed several numbers through the keys up down and pressed ok on 99. then I recieved the init unable. Im close to bin this thing.
