Timex Expedition E Tide Temp Compass wristwatch Logo
Posted on Nov 24, 2009
The light on my timex expedition e-tide temp does not work when you press the middle button
5 Related Answers
Anonymous
  • 2071 Answers
  • Posted on Jun 14, 2008
SOURCE: Timex EXPEDITION® E-TIDE-TEMP-COMPASS T45581
most of my repair does'nt have a manual,all i do is to sure that all,the function button is working.then proceed to try all the function to work and observed what is the result.that watch three sitting of the crown by pulling,first pulled little then wind left and right and observed,second half pulled,then wind again third full pulled for hands function.Try this and you find the result.
Anonymous
  • Posted on Jul 11, 2008
SOURCE: Expedition Indiglo Waterproof 50m
Purchased Indiglo WR 50M. I purchased AT 6150/-. What is the origial cost of the watch?
Anonymous
  • 3 Answers
  • Posted on Aug 18, 2008
SOURCE: Timex Expedition Indiglo light no longer works?
Replace the back cover with the arrow pointing directly at the stem. Everything should work correctly with the cover in that position.
Anonymous
  • 3614 Answers
  • Posted on Sep 09, 2008
SOURCE: Timex W-225 -- the tide
have you try changing the battery...?
or-
did your watch has been been dropped?
Anonymous
  • Posted on Jun 17, 2009
SOURCE: How to replace battery for Timex expedition
Remove the four screws that hold the battery cover on the back of the watch. Remove the 3 very small screws that hold the battery in place. Remove the battery from the battery holder. The piece that the 3 small screws were removed from seperates from the 3 volt 2016 energizer battery. Replace the battery with a new one. Re-install the battery holder to the watch. There is a small tab on the lower left part of the battery holder that needs to be depressed to activate the watch. Depress it and look at the face of the watch to make sure it is activated. The watch will need to have the time, date etc reset but you should now be able to see that the battery is working. Replace the battery cover and reset the time and date as needed.
Manual for timex expedition e
There are two ways to find the user manual for your Timex watch.
  1. Find your watch on the list below and click on the language link for your manual.
  2. Find the 3-digit module number located on the caseback of most Timex products and click on the corresponding language link for that number in the Module Table
If you are still unable to locate your user manual, you may email Timex Customer Service or call toll-free at 1-800-448-4639
http://www.timex.com/info/Product_Instruction_Guides_Downloads
5answers
Timex W-225 -- the tide and temp button are non-responsive
or-
Replace stem on Timex Expedition E-Tide Temp Compass Watch
I am looking for stem and crown for Timex Expedition North Tide Temp Compass watch. Mine broken.
4helpful
How do i calibrate my compass on my e tide watch?
Click on my profile (escapement), then click on Tips and Tricks. There you will find link to all TIMEX watch manuals. Rate me, please..
1helpful
I have a Timex e-tide with compass, temp and tide functions. The compass no longer points north and will randomly point in any direct when activated, is there a way to re-calibrate the compass?
Use the numbers on the back of your watch and you will have a PDF version of your instruction manual.
Hope this tip helps
R/
David
4helpful
Instructions for timex e-tide temp compass watch
Hope this tip helps
R/
David
Timex exp e tide compas will not work / calibrate
i would advise you to contact timex customer services .
5helpful
2answers
No instruction manual
For Compass Adjustment search on Google or FixYa
For Temperature calibration:
1. Pull the crown to most extended position (2 notches)
2. Temp hand moves to a default position
3. Move hand in + or - direction by pressing temp or tide buttons (above and below crown button)
4. When done, push crown to 0 position
(I used melting ice water to calibrate and fix to 0 deg C)
For Tide calibration:
1. Pull crown to middle position (1 notch)
2. Move hand in + or - direction by pressing temp or tide buttons (above and below crown button)
3. When done, push crown to 0 position
Hope this helps
3helpful
3answers
This is the link;
http://assets.timex.com/instructions/w225instr.pdf
Top Timex Watches Experts
Paul Bade
NOEL
NOEL
Ngoro
Are you a Timex Watch Expert? Answer questions, earn points and help others
