Green & Yellow light on Ryobi 14.4V charger
It sounds like your battery is bad.
If both yellow and green LEDs come on, this indicates
a deeply discharged or defective battery pack.
Allow the battery pack to remain in the charger for 15
to 30 minutes. When the battery pack reaches normal
voltage range, the red LED should come on. If the
red LED does not come on after 30 minutes, this may
indicate a defective battery pack and should be
replaced.
n After normal usage, a minimum of 1 hour of charging time
is required to fully recharge battery pack.
SOURCE: Green and yellow light on charger; Battery does not charge.
check the terminals or wirings if it has detached,or its fuse,if after doing it you find out that your fuse is good,then your battery battery needs to be replaced
