"F2" means your membrane keypad is shorting.
If and when an oven is coming on or doing anything by itself, this is very dangerous and can result in a fire.
So until it is repaired, please leave it unplugged or leave the door
open when it's not in use, and of course, never leave an oven cooking
unattended.
You can order the control panel frame assembly with a keypad already installed here
You can also find handy exploded views there. Just do a search by full your model number (KHMS155LSS1, KHMS155LSS2, KHMS155LSS3, KHMS155LSS4, etc.).
You first unplug the oven and remove your control panel assembly as per the video at
our site.
Then disconnect the keypad strip as per the picture below.
Then you take out the screws holding your circuit board to the old frame and put it in your new frame
Be careful, since the display is glass.
Reassembly is the reverse of disassembly.
We're
happy to help you with free advice and we'd appreciate your
thoughtful rating of our answer.
Faulty control panels for Kitchenaid KHMS155L series microwaves are being replaced by Whirlpool at no charge for part or labor. This is a recall due to the possibility of the unit turning on when not attended and starting a fire. If you have observed F2 code or have observed the unit turning itself on , call Ava at Whirlpool at 1-866-640-7146, ext 6337 and be ready to give her your complete model and serial numbers. She will arrange for A
