Adcom GFA-5802 2-Channel Amplifier Logo
Anonymous Posted on Nov 23, 2009
1999 ford expidition eddie bauer. what number fuse in the box is for the horn?
Anonymous
Level 3:
  • Master 3,741 Answers
  • Posted on Nov 23, 2009
Anonymous
Master
Level 3:
Answers
3741
Questions
0
Helped
974984
Points
10483
Flip Window Relay Fuse 29 Fog Lamp Relay Fuse 9 Fuel Pump Relay Fuse 19 Headlamp Relay Fuse 8 Heated Grid Relay Fuse 27 Horn Relay Fuse 5 Engine Fuse Module (Fuse 1) Fuse 24 Engine Fuse Module (Fuse 2) Fuse 16 Engine Fuse Module (Fuse 3) Fuse 6 Engine Fuse Module (Fuse 5) Fuse 6 This will help. Thanks please keep updated. please do rate the solution positively .thank you for using fixya.
Where is the relay feeding the headlights on a 2000 Ford Explorer Eddie Bauer model?
Jeff Armer Sep 22, 2021
Has no relay for headlamps , just fuse's , fuse # 12 30 amp under hood fuse / relay box and fuse's 33 , 4 and 8 fuse box inside the vehicle .
2answers
99 eddie bauer ford expedition horn relay location
horn relay (located in the battery junction box [BJB]).thanks
My horn stoped working, when I press the horn I only hear a click.
There was a recall done on those vehicles in 2008 for the same issues. Something about a clock spring. If the recall work has not been done on your SUV, bring it to a dealer.
3helpful
I have a 97 ford expedition eddie bauer an my horn dont work i test the horn and its good i test the wire an there was no power an i dont no were the fuse located at
ok there should be 2 fuse boxes on this vehicle one under the driverside dash one under hood your horn fuse is under dash replace and replace your horn high resistance will cause the horn fuse to blow
Ford expidition 2007 transmition problem
I had the same problem. I took the truck into the dealer and there was a computer software upgrade that needed to be installed that altered the shift points in the transmission. After that 10 minute fix, I have had no other issues.
Top Adcom Audio Players & Recorders Experts
 Grubhead
Grubhead
Steve Sweetleaf
Steve Sweetleaf
Ian Ne
Ian Ne
Level 1 Expert
Are you an Adcom Audio Player and Recorder Expert? Answer questions, earn points and help others
