Canon PowerShot SD400 / IXUS 50 Digital Camera Logo
Posted on Nov 23, 2009
Can I take timed pictures - Canon PowerShot SD400 / IXUS 50 Digital Camera
If i put my camra on self timer win i print the pictures will the time show up on the pictures
The time it took the picture? You want to know if the camera will show the time it took the picture using the self timer?
My answer is Yes and No.
Do you have your camera set to showing the date and time on the pictures now? If you do, then using the self timer would not change anything.
If you do have it set to showing on the picture and you don't want the date and time to show then change the setting on the menu function of the camera and turn this option off.
If you do not already have the camera set to show the date and time, using the self timer option is not going to make it suddenly appear.
tip
SONY GRAND WEGA ERROR CODES AND WHAT THAY ARE
Lamp cover error 3 times - Lamp cover is not fastened securely - No picture/No sound
Fan error 4 times
- Fan1-4 Power is not supplied.(G2 board)
- Fan connector is not seated securely
- Fan caught wires or harnesses
Temp error 4 times
- Internal temperature is too high
- IIC-E line connector is not seated properly
(WE:H3 board, WF/XS:H4 board)
Lamp driver error 5 times - Lamp driver defect - No picture/No sound
Low B error 6 times -No "DD 6V " output (G1 board) - No picture/No sound
Audio error 7 times
- Short-circuit of Audio power supply line
(KD board, G1 board)
- Blowout of a fuse
(F4702,F4703,F4704 on KD board)
- IC failure
(IC4703,IC4708,IC4710 on KD board)
D-OVP error 8 times
- Overvoltage of +3.3V or +2.5V
(A board, B board)
ATSC-OVP error 10 times
-No "DTL MODULE 5V " output
(G1 board, G2 board)
Lamp error LAMP-LED is ON. - Lamp is dead - No picture/No sound
5helpful
2answers
TV was working fine, moved to new home and the problem began. Picture rolls to the right, picture is fuzzy and will clear up somewhat at times. The picture will stop rolling at times also,but may be a half...
TV was working fine, moved to new home and the problem began. Picture rolls to the right, picture is fuzzy and will clear up somewhat at times. The picture will stop rolling at times also,but may be a half and half screen. Sound is fine, can you help me with this problem please.
2helpful
My wife`s Kodak Easyshare V1253 has to be reset (date and time) every time we replace the battery. What could the problem be? Also, it takes too long to take one picture from another (probably setting...
Regarding the date and time, Actually its normal everytime you removed the battery you need to reset the date its is because the camera doesnt have a internal or built-in battery that can run the internal clock or maintain the date settings.,
Regarding the taking picture that will take time, it is because your using a too high mega pixel of the camera, Higher mega pixel will have a bigger file size and it will take to process the picture. the best thing you can do is to lower the Mega pixel or the picture size make it atleast 5MP or 6MP., I can guarantee to you you will have a great picture outcome and lessen the time of processing picture.
By the way you can lower the mega pixel (picture size)by pressing the menu button of your camera
3helpful
Pictures to download to computer with date/time ?
Only if the date and time stamp was used while the pictures were being taken and appear on the pictures when previewed
No date and time printing on the picture
It does not print on the picture. After downloading right click on picture and then click properties and it will show time/date. You can find programs to add time/date programs to add after download.
My camera is a PowerShot A460. It can take pictures but all white
It looks like you took pictures on Manual mode and didn’t set the Exposure Compensation and Shutter speed properly. If you can get good pictures on Auto mode, your camera is ok.
Taking pictures
Hallo
First, try to use different batteries. it can cause to long reaction times
Second, try to buy a faster memory card, it usually help for the time it takes to upload and see the pictures on the screen
about the blurry pictures
are you using M or a different mode?
HOW TO DISPLAY DATE AND TIME
I checked the manuals and I believe that the function you want is not available within the camera menus.  The date, time, and lots of other information is included within each file that holds individual pictures.  The software you use to view and edit pictures should show the information to you and may allow you to manually add the date to the picture.  I use Photoshop Elements 6 (Mac) and it will allow me to put the date and time on a picture.  You might consider adding the date and time to the name of the picture file if you want a quick reference to the date and time
Hi again
yes 3x its lamp cover no doubt. ballast supply will give different error on this unit. this should help hdtv man
Diagnostic Item
Description
Number of times
STANDBY or LAMP LED
lamp flashes
Probable Cause Detected Symptoms
Fan error 4 times
Temp error 4 times
Audio error 7 times
- Blowout of a fuse
- IC failure
D-OVP error 8 times
(A board, B board)
Top Canon Cameras Experts
old marine
old marine
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Canon Camera Expert? Answer questions, earn points and help others
