That's because you are using Auto mode, aperture and shutter speed is done automatically by the camera. Try to use the manual mode, ISO 800, speed 60 and lens aperture 2.8. Use a tripod to avoid image blur due to camera shake
Check the settings of the camera. Put the recording mode for stills (photos) to auto, so the setting can't stop the camera from taking a picture. If you are in one of the manual modes, and the system calculates it won't be possible to make a picture (to dark, to light, or out of focus and so on) it won't react when you press the shutter release button.
Please use the manual, so you will be able to solve this every time it happens to you. The manual is still online.
You have to know the MODE your camera is in. If you have it in the wrong mode you may not be able to take a photo in some conditions. You typically cannot take a photo of the moon on any auto setting the moon will be a white blob. The moon almost has to be taken manually.
Search for Lens Error. There are many was to fix Lens Errors
l For manual copy density adjustment, press the AUTO/ MANUAL/PHOTO ( / / ) key to select MANUAL ( ) and adjust with the LIGHT ( ) and DARK ( ) keys as desired. l For photographs, select PHOTO ( ) and then adjust with the LIGHT ( ) and DARK ( ) keys as desired. l There are 9 exposure steps indicated by 5 indicator lights. (The indicators light up one or two at a time.) Successive pushes of the LIGHT ( ) key will change the indicator lights in the order (3) / (3•2) /(2) / (2•1) / (1). Successive pushes of the DARK ( ) key will change the indicator lights in the order (3) / (3•4) / (4) / (4•5)/ (5) The automatic exposure level can be adjusted to suit your copying needs. 1 Press the AUTO/MANUAL/PHOTO ( / / ) key to select the PHOTO ( ) mode. 2 Press and hold the AUTO/MANUAL/PHOTO ( / / ) key for approximately 5 seconds. l The PHOTO ( ) indicator will go out and the AUTO indicator will begin to blink. l One or two exposure indicators corresponding to the automatic exposure level which has been selected will light up. The factory default setting is level “3”. 3 Press the LIGHT ( ) or DARK ( ) key to lighten or darken the automatic exposure level as desired. 4 Press the AUTO/MANUAL/PHOTO ( / / ) key. l The AUTO indicator will stop blinking and will light up steadily. l This automatic exposure level will remain in effect until you change it again by this procedure. Automatic exposure adjustment AUTO
I had the same problem before. Did you check to make sure your exposure compensation wasn't set at a negative number? half press the shutter and rotate the large dial on the back of the camera to change the exposure to 0. If this just changes your auto focus points, you have to change your custom function 13 from a value of 2 to 0 and then try half pressing the shutter and rotating the large dial in the back again. This fixed my problem with shooting in P mode (which I only used when absolutely necessary) and I hope it helps you.
If you are in full auto the camera is going to meter to the brightest point. If your subject is in the sun you should be ok but if your subject is shaded then they will come out dark becouse the camera is metering for the brighter background. You might try seting your camera in AV or TV mode and then set your camera to a single AF point. This will let you camera meter to just your subject and not the background. Youe could also try using a flash fill to balance out the light.
anyone else had this? or know what to do.
whatever best you can do is to take the camera to a good repairer as you can't fix the problem by yourself. there may be two possible reasons for the problem. 1) bad image sensor i.e. damaged CCD or 2)shutter blade are not working. the shutter blades may be jammed due to friction are no signal.
Panfocus mode on the F505 appears to convert the lens to a fixed-focus design,
(everything in reason is always in focus) presumably by stopping down, and perhaps by doing other lens adjustments.
So "panfocus" must mean "the whole world is always in focus", instead of "quickly focus as you pan", as at least one reviewer has misinterpreted it. This feature is very handy for a couple of reasons. First it eliminates the autofocus
delay, cutting the shooting time down to just the shutter release delay. And
second, it allows for shooting in total darkness, since the image is always in
focus.
