Hi how can i turn on date stamp on my canon ixus 75 ta
The date and time (and a lot more) are stored with every picture in its EXIF metadata. Any photo viewing/editing program should be able to display this data. To print this data, please consult the documentation for whatever program you're using to print your pictures. Depending on the program and printer you may print the date on the image, in the margins, or on the back.
SOURCE: how to set date stamp for canon ixus 860is
The date and time can be included on the pictures taken only with the camera in postcard mode. You must also activate the date stamp option in the menu.
To set the camera into postcard mode, press the [Func.] button on the camera, then use the [arrow down] key to go down to the last option in the menu, and there you can choose the [Postcard mode]. Press [Func.] again to exit the function menu.
To set the date and time stamp, press the [Menu] button and then use the [arrow down] button to go to the [Date stamp] option in the menu. You can set this to "Date" or "Date & Time". Press the [Menu] button again to exit the menu.
Be
aware that if you take pictures with this option enabled, the Date and
Time cannot be removed from the pictures at a further time. It will
permanently appear on the picture.
Please rate my help++++Thanks for using FIXYA
SOURCE: battery display on canon ixus 75
Its same for everyone. You can only see the battery when its about to run out. IN that case a red flashing icon appears on the upper right corner of the screen otherwise there is no indicator for ixus 75.
SOURCE: Canon Ixus 75:
Image size (L, M1, M2, M3, S, Postcard) must be set to Postcard. Then make sure that on the Record menu Date Stamp is set to Date or Date/Time.
SOURCE: hi all, pls hep me
The date stamp only works in Postcard mode. Press Func/set, scroll down to the bottom, then across to the mountain with clock icon. "Postcard" will appear in the selection. Press Func/set.
Now press Menu, scroll down to Date Stamp and across to set date or date and time, then press menu again.
SOURCE: How can you remove the
Assuming this is actually a Canon IXUS 82 IS (not an 8215 which doesn't exist), I found on page 20 of its user manual that you have to do the following:
Slide the Mode switch to the top setting
Press the Func. Set button
Press the right or left arrow until you see the camera icon that stand for "Auto" (see manual)
Use the up and down arrows to select the "L"
Use the right or left arrow to select the last icon at the right that looks like a clock in front of a picture
Press the DISP button
Use the right or left arrow to de-select [Date/Time]
I suggest that you look at the user manual directly, since some of the above doesn't make a lot of sense without seeing the icons.
Thanks for using FixYa and Happy New Year!
