Well you didn't specify what kind of motor it is just that it's a 1994. If it runs when you use starting fluid but dies then the problem has to be fuel. I'm assuming you've changed the fuel filter. I'm not sure what kind of an engine you're talking about here but if it hasn't been run for two years and it has a carburetor the float could be stuck. If it is stuck in the up position this would block fuel from entering the carburetor. Check it, the fuel filter and the line coming from the tank and trace the fuel supply all the way to the engine from the tank.
