Brendadeese, You might be able to repair it. Well your husband or boyfriend maybe. If good with a soldering iron, solder-wick, solder, and $5-$12 in new filter capacitors. You should have visited YOUTUBE for video clips of "LCD monitor disassembly"and "LCD monitor repair" to see just what is involved with making BLACK SCREEN of DEATH go away. Most LCD monitors (98%) use same basic backlighting technology. Here are some repair options for you to ponder over! A. If KDS has a swapout program for BSoD units try it first! B. Contract out the REFURBISHMENT work to reputable local firm that knows exactly what is needed to do the work properly. C. Trade in for new unit. But remember that the tech in the back of the store is going to repair your unit with a little luck and have a nice monitor to give to his kids on Christmas, and won"t need to do it again till Christmas 2011 or 12. I would also recomend a visit to www.ccl-la.com/badcaps.htm to learn what may be the cause of your BSoD. FYI If K92MDWb had a crisp, bright, colorful image just prior to BSoD, try doing the flashlight test so you will know if the units "switch-mode-power-supply" is in "full" or "partial" shutdown mode. 12fixlouie If this was of some help, please rate on fixya.
My kds k-92mdwb monitor goes black after a few seconds. How can I fix this?
This trouble maybe power supply or inverter boards is defective.
first you can test the voltage of the multr,and then check which part is defective.From Wisiny.com can find those parts
if you have any question,please let us know email:[email protected],we sincerely hope we can help you!
you can also check this boards whether suit you:
860 AB0 190DTLB PCH 200 000 170DTLBMH PI 190DTLB ETL XPC 204...
Replaced caps, picture is reddish for a few seconds before turning off. when using a flashlight, i can see lcd graphics drawn. any oother ideas ?
