Garden Logo
Posted on Nov 22, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Chain sprocket worn out
How do I replace the chain sprocket on my Poulan PP4218. I have removed the Snap ring but the sprocket will not move.
  • Anonymous May 11, 2010
    It has an inboard clutch. Similar to this: R² Drive Link Inboard Clutch by Drivelink.blogspot.comhttp://www.youtube.com/watch?v=YUbSIHMSS... The C-clips tend to fly when being removed. Please wear eye protection and exercise care. If you have removed the C-clip and washer try tapping the clutch drum assembly, it should pull straight off. I suspect a spring inside the housing has failed. An IPL (exploded parts list) for your saw can be found here? Poulan.comhttp://www.poulanpro.com/node4043.aspx In the "Type your search query (i.e. product name)" enter "PP4218" Uncheck "Operators Manuals (OM)" Check "Illustrated Parts Lists (IPL)" The clutch detail is the same on all three, item 11 is your clutch drum. Item 13 is the actual clutch and is a left handed thread. If necessary to remove it you will find this helpful, please watch this: R² Drive Link Outboard Clutch by Drivelink.blogspot.comhttp://www.youtube.com/watch?v=cdqkIuVNU... Check the IPL for your saw to see if any special tools are needed. There are metal piston stops available, when square (almost never) with the piston top these work well, if not square they have been known to punch through the piston. I suggest a length of starter cord or nylon rope be used instead of the piston stop (retain 6" ± so you can remove it). Make sure the piston is near the top of the cylinder before feeding the cord or it can fall through the exhaust port and damage the piston as it rises. Everyone I?ve ever removed had a left handed thread (tighten it to loosen it). Let us know how it worked for you. GLLou
Roland W VanLue
Level 3:
  • Master 486 Answers
  • Posted on Nov 22, 2009
Roland W VanLue
Master
Level 3:
Answers
486
Questions
0
Helped
315009
Points
1454
Outboard drums (drums on the outside of the clutch) are held on by a nut or e-clip.
Inboard drums are held on by the clutch which is threaded onto the crankshaft. And there is the challange.
***NOTE all chain saw clutches have LEFT hand threads, so, rightey loosey, lefty tightey. (just backwards from everything else)
*** NOTE #2: DO NOT USE AN IMPACT GUN
this will most certainly shear the flywheel key or damage the flywheel !!!!! (after 35 years, you can ask me how I know that, LOL)
1) Use a piston stop to hold piston from moving: THIS IS A MUST !!!
Ok, so you do not have one, let's make one.
a) remove the spark plug
b) insert a piece of recoil rope into the cylinder hole, leaving a tail to remove it by. (rope, large shoe string, anything that is soft, that is aprox 1/4 to 5/16 in diameter to place into the spark plug hole to help the piston to stop it's travel by filling up the empty space. Just make sure you can remove it later)
c) secure the saw (extra set of hands may be needed) and with a suitable wrench on the clutch center, rotate the clutch to the right until piston comes to a stop. With a hammer, tap the wrench to aid in rotation. This can be very difficult, and may take several taps.
d) after removed, inspect and grease the drum bearing before re-assemlby.
e) upon re-assembly of clutch, tighten by hand only, NO hammer required. The force of the chain will tighten the clutch.
f) remove the rope, and re-install the spark plug.
I’m happy to assist further over the phone at https://www.6ya.com/expert/rolandw_c013176d62ee17ae
Anonymous
Level 3:
President:
  • Master 2,220 Answers
  • Posted on Nov 23, 2009
Anonymous
Master
Level 3:
President:
Answers
2220
Questions
Helped
1383837
Points
7625
http://www.youtube.com/watch?v=YUbSIHMSSP8
An IPL (exploded parts list) for your saw can be found here:
Poulan.com
http://www.youtube.com/watch?v=cdqkIuVNUQc
  1. Check the IPL for your saw to see if any special tools are needed.
  2. There are metal piston stops available, when square (almost never) with the piston top these work well, if not square they have been known to punch through the piston. I suggest a length of starter cord or nylon rope be used instead of the piston stop (retain 6" ± so you can remove it). Make sure the piston is near the top of the cylinder before feeding the cord or it can fall through the exhaust port and damage the piston as it rises.
  3. Everyone I’ve ever removed had a left handed thread (tighten it to loosen it).
Lou
  • Anonymous Nov 23, 2009
    I've thought about your problem, is the chain brake released? If the chain brake is engaged you won't be able to remove the drum. Pull item 36 aft slowly but with some force. It will click when the keeper engages the detent if the brake it is engaged. I think this is addressed quickly in the film. Lou
How do i unlock brake on a Poulan wildthing 2375 chainsaw
First, stop your engine. Check to make sure that the chain brake isn't engaged. The chain brake can activate automatically by a sudden movement or impact. You can disengage the chain brake by pulling the chain brake hand guard back against the front handle and releasing slowly. If the chain brake is disengaged and the chain does not turn; turn off the saw, then check the drive links on the chain, the bar groove and the sprocket nose on the bar. A burr on the drive links will bind the chain in the bar. If the bar has been pinched, the chain will not pass freely through the groove. If a sliver of wood has gotten into the sprocket nose, it will not turn at all. Also, look at the drive sprocket on the saw itself to see if it has a groove worn into it. A drive sprocket with a groove worn into it will damage the chain.
tip
Drive Hub, Spring Pulley & Chain Replacement for Steppers
Video about the Drive Hub Replacement Procedure for Stairmaster Steppers
  • This videocovers replacing the spring pulley, the step chain and the drive hub assembly on the Stairmaster steppers
  • Tools needed:
    • Snap Ring Pliers
    • Tip Kit for Snap Ring Pliers
    • Socket Wrench
    • 7/16" Socket
    • 7/16" Wrench
    • Needle Nose or Standard Pliers
    • Safety Goggles
  • Begin by disconnecting the spring
  • Do this by pulling up on the spring and unhooking the spring from the frame post
  • Next, using the snap ring pliers and proper tips, remove the snap ring from the spring pulley shaft
    **Important: Be sure to wear safety goggles when working with snap rings**
  • Remove and inspect the spring pulley for any flat spots replacing the pulley if necessary
    • Flat spots develop over time and can result in roughness in the pedals
  • On the side that the pulley was just removed, slowly press the pedal down
  • Remove the step chain retainer brackets (if equipped) using the 7/16" wrench, 7/16" socket and socket wrench
  • Once the retainer bracket is removed, the spring can be lifted up over the drive sprocket and disconnected from the chain
    • The spring is opened at one end to allow for maneuvering over the link
  • Using the standard or needle nose pliers, remove the master link attaching the step chain to the pedal arm
    • Place one jaw of the pliers against the open end of the clip (if installed correctly, the open end of the clip is opposite the direction of chain travel) and the other jaw of the pliers against the far side of the nearest rivet coming through the keeper link; and squeeze pliers together
    • This should pop the clip free allowing you to remove it from the master link
    • Next remove the link bar
    • Finally remove the master link disconnecting the chain from the pedal arm
  • Inspect the new step chain making sure all the chain links flex
    • Manufacturer recommends lubricating the step chain with 30W motor oil using a clean rag to remove any excess
  • Attach the new step chain to the pedal arm reversing the steps taken to disconnect the chain
  • Relieve tension on the opposite spring by lifting up on the spring and unhooking it from the frame post
  • Slowly press the pedal down
  • Feed the spring around the pulley and lift the chain up over the sprocket to move it out of the way
  • Disconnect the remaining two bolts from the drive hub assembly
  • Lift the drive chain over the sprocket and pull the drive hub from the frame
    • As the drive hub assembly starts to develop problems, you may feel clicking, hear some grinding sounds, or a pedal may stick in one position (which usually happens on one side); All of which are indicators of a worn drive hub assembly
    • The drive hub can be replaced as a complete unit
      • The drive hub consists of (3) sprockets
        • Two one way clutch sprockets that drive in one direction and slip in the opposite direction which are for the step chains
        • A larger sprocket that spins either direction and is for the drive chain
    • An inspection of the drive hub can help determine need for replacement
          • If either of the one way clutch sprockets slip in both directions, they need replaced
          • If there is a catch in any of the sprockets in any position, then it likely needs replaced
  • Reinstall the drive hub the same way it was removed
  • Slip the drive chain over the drive sprocket before mounting the hub assembly to the frame
    • The drive hub assembly on the SC916 stepper only has 4 bolt positions. The drive hub assembly on the 4400 and 4600 steppers has bolt holes all around the hub allowing the hub to be rotated for chain tension adjustment. The SC916 stepper has a preset tension and the adjustment is no longer necessary
  • Once the drive hub is bolted to the frame, reinstall the step chains on each side
  • Place the free end of the step chain (opposite the pedal arm connection) up over the step chain sprocket
  • Lift up on the pedal and pull down on the step chain
  • Place a hand on the sprocket keeping the step chain from feeding back and allowing the pedal to drop
  • Grab the spring with your opposite hand and join the spring to the step chain
  • Once the spring is attached to the chain, press the pedal down again
  • Reinstall the spring pulley and the snap ring onto the pulley shaft
  • Lift up on the pedal and pull the spring to route through the pulley, hooking the spring onto its frame post
  • Repeat these steps to attach the step chain and spring on the opposite side
  • Reinstall the step chain brackets (if equipped) making sure all bolts face the same direction
  • This concludes the video demonstration of replacing the drive hub, spring pulley and chains on the Stairmaster steppers
Spring Pulley Chain Drive Hub Replacement Video for Stairmaster Stepper...
tip
Drive Hub Assembly Replacement for Stairmaster 4000PT Stepper
Stairmaster Stepper Drive Hub Assembly Replacement
  1. Remove the side covers.
  2. Remove the step chain retainers.
  3. Supposrt the pedal arm. Unhook the pedal arm return spring from the spring hanger. Lift the step chain up and off the clutch sprocket and lower the pedal arm to the floor. Repeat on the other side.
  4. Remove the snap ring from the left end of the drive shaft. WARNING: To reduce the risk of eye injury, wear eye protection when removing snap rings.
  5. Remove the drive chain.
  6. Remove the sprocket and other small parts from the left side of the hub assembly.
  7. Slide the drive shaft to the right, out of the hub assembly. If you remove the right-hand clutch sprocket form the drive shaft, do not confuse it with the left-hand clutch sprocket.
  8. Loosen and remove the two remaining bolts and nuts that hold the hub assembly to the frame. Remove the hub assembly.
  9. Inspect the drive shaft, bushings, thrust washers, and clutch sprockets for excessive wear or pitting. Replace any worn components.
  10. To reinstall the hub assembly, carefull reverse the disassembly procedures. Be sure that the right- and left-hand clutch sprockets are positioned correctly; the wide shoulder of the sprocket should be facing away from the hub on both sides.
  11. Chain Tension. The drive shaft is mounted in an eccentric hub. Rotate the hub so the marked hole is in the 12 o'clock posistion, lining up four holes in th hub with the four holes in the frame. Use this hub position when reinstalling the drive chain since the distance between the drive and the transmission shafts is at a minimum. The hub is in the proper position when the drive chain has a total of 1" to 1-1/2" of play, up and down, at the slackest point in the chain. If it is necessary to increase the tension or tighten the chain, rotate the hub counter clockwise until the chain has proper tension.
  12. Reinstall the covers.
How to Repalce the Drive Hub Assembly on Stairmaster 4000PT
Poulan 18" PP4218 Pro 952051338 It has fuel
you may need to clean your sparkplug, or replace it
Purchased like new PP4218 from local, bought for his son, after one tree, son lost interest. No manual with saw. What chain and bar do I buy as replacements? He replaced chain, not sure it is correct...
it's an 18 " poulan bar and chain...just a standard bar and chain for poulan...most of the aftermarket brands have a cross reference that will give you an idea on which to use
1helpful
Chain does not rotate around bar. Chain brake seems to engage/disengage as intended.
With a gloved hand can you manually pull the chain around the bar? if not the chainbrake is still engaged, pull the hand guard fully back to the top handle until you hear the click from the brake mechanism, if the chain does pull around manually then there is a problem with either the cluch or the sprocket, remove the side cover, check the clutch for damage, remove the drive sprocket and check the drive teath are not badly worn allowing the chain to slip within it, replace parts as required.
Why would a drive sprocket on a poulan wild thing 18" chainsaw wear completely out in less than 35 hours use?
This will happen if your bearing goes out or if you install a chain that is damaged on your saw. If the chain is in bad shape, it puts extra stress on the sprocket, thus making it wear out quicker. Same goes for your bar. Although noone normally does, it is "best" to replace all 3 items at the same time. Usually, though, if there is no visible damage, it's ok to replace just the worn out piece.
You can find replace bars, chain & sprockets for your saw at partsbuggy.com.
3answers
Rattling noise coming from the engine of my 1993 kawaski zxr 400
usually kawazaki zxr 400 has these problem the main reason is due to the overspeed.only authorised kawazaki dealer can solve it.....
My chain saw starts but won't move the chain, and shuts off when
Make sure the chain brake is not engaged.Pull it toward the handle until it latches.Also check for sawdust under the chain sprocket cover.Adjust the chain to remove slack but make sure you can still move it by hand.
2answers
Poulan pro series chain saw 20" bearings seizing up on bar
check sprocket isn't worn it may be pulling on chain than over heating bearing. check pitch of chain ,bar , sprocket are the same.
Top Poulan Garden Experts
Jay Finke
Jay Finke
Thomas Perkins
Thomas Perkins
Sean Wright
Sean Wright
Are you a Poulan Garden Expert? Answer questions, earn points and help others
