Question about Ricoh Office Equipment & Supplies
This message appears when I turn on the copier ? Ricoh aficio 340 ? Functional problems SC101-00 what this message means
  • hell_fire_ok Nov 24, 2009
    thanks a lot for your help
    President:
  • Ricoh Master
  • 990 Answers
Hello sir; SC101 means " exposure lamp out" you need replace one.
Posted on Nov 22, 2009
6ya staff
SOURCE:
Turn main power switch off then on.If error reoccurs.call service.Functional problems. What does mean.
It means that something with the functionality of your device is not working properly. Take it for service.
Mar 07, 2016 | Ricoh Aficio 1018D Copier
How to solve this problem sc 302
Hi
I managed to find a list of Ricoh error codes with brief explanations of their causes here:
Ricoh copiers error code messages
This clearly identifies the problem as a laser motor problem - OR
Charge roller, HVT, or fuse FU5 (AFICIO 340, 350 series, 355, 450 series, and 455) - OR
SC-302-01, 02, 03, 04 Charge corona assembly Aficio 550/650
SC-303 Charge corona wire cleaner, disconnected or time out for printer.
All of these sound rather like an engineer requirement but you may be able to something with appropriate spares
Sep 25, 2014 | Ricoh Office Equipment & Supplies
Functional problem
change the td sensor below the developer unit or if possibly change the complete developer unit
Jan 02, 2014 | Ricoh Aficio 1035 Copier
I have a ricoh 2051 with this error message: Functional problem within the machine. Turn main power switch off and then on. if the error appears again, then call Here is the error message code: SC...
After turn the main switch off and on the error appears again????
This error means that there is a bad comunication between the controller board and the operation panel.
Did you intervew in the machine? Some tecnical intervewing?
Feb 17, 2011 | Ricoh Aficio 1035 Copier
Ricoh Aficio 2027, Service Code 320
dear sir; the error code 320 on ricoh af 2027 it's means laser polygon motor problem, the laser unit right under the toner unit, litlle bit left. some error code can be reset why don't give them a try
1, power on the machine
2, press "clear mode"( has the c in a diamond), "107"then press and hold down "clear/stop" key
3,turn power off 10 second later back on.
I f reset doesn't work, you need to replace laser motor. thank you
HAVE A HAPPY HOLIDAY
Dec 17, 2008 | Ricoh Aficio 1035 Copier
Ricoh photocopier 1075 code sc541
Ok, its a firmware bug, but you should be able to reset it. Press clear modes, 1, 0, 7, and press and hold clear/stop. Press 1 for copy sp. Scroll down to 7, (data log) press 7. scroll to 7807, and reset it. exit all the way out, and recycle the power.
Mar 18, 2008 | Ricoh Aficio 1013F Copier
Ricoh aficio 200
Ricoh Aficio 200 copier has stopped copying from side tray. Can you help?
jimgoatley@slingshot.co.nz
Feb 17, 2008 | Ricoh Aficio 180 Laser Printer
Ricoh Aficio 1018 photocopier
MY PHOTOCOPIER IS ASKING FOR CODE SC194
Nov 30, 2007 | Ricoh Aficio 1018D All-In-One Laser...
400 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
Bernard D'Souza
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
