The Compaq Tablet PC TC1000? (Marketing Part Number D 70045-236)
Turn the laptop over, you're looking at the bottom. Battery Compartment is to the Right.
To the left of the battery compartment is the Memory Compartment. (The parting line for the memory compartment door, starts to the left of the battery release button)
The Memory Compartment is rectangular in shape. The right lower corner has a half U shaped cutout. (Next to the battery release button)
At the top of this panel, or door, are two Philips head screws. These are removed. The panel is then lifted up at the side the screws are on, SLIGHTLY, then slid forward. (Forward. Away from you)
(There are two plastic tabs at the end towards you. They slide into the body of the laptop, and if the panel is lifted Straight up, these small plastic tabs could break off)
This is HP Support, and the download page for Manuals, for the Compaq TC1000
(HP and Compaq are one, and the same entity now)
http://h20000.www2.hp.com/bizsupport/TechSupport/DocumentIndex.jsp?contentType=SupportManual&lang=en&cc=us&docIndexId=64179&taskId=101&prodTypeId=321957&prodSeriesId=307008
I would like you to download the Hardware Guide for this tablet PC. It explains about the hardware, and also shows how to install ram memory.
(Copy and paste the above link to your address bar, press the Enter key)
Under the - General Reference - section heading.
Click on - Compaq Table PC TC1000
Series Hardware Guide
(Second one down)
This is a PDF file. Your computer has Adobe Reader on it, which uses PDF files.
I advise letting it download all the way before looking through it, or you may break the download connection.
Page 128 starts with telling you how much is the Maximum Amount of ram memory.
(512MB)
Tells you that there is only 1 Ram slot.
The next page tells, and shows you how to open the Memory Compartment door, then details how to remove,and install ram memory.
