I forgot my password nd can't watch ratings over tv14 or PG
Good Day,
Bypassing the V-ChipLock
After you set the lock, you need your passcode to view a V-Chip locked program, view the locked TV, cancel the lock, or enter the V-Chip lock menus. If you forget your passcode, you can view the locked TV without entering your passcode. When your password is requested, press the number 9 and QV buttons on the remote TV control at the same time. This process temporarily unlocks the TV. When entering the V-Chip Lock menu, this process deletes your old passcode and prompts you to enter a new passcode.
When changing or deleting your passcode, you must use the remote control included with this TV. You cannot use any Mitsubishi remote control from another component or a "universal" remote.
Good Luck, Big Irish.
Turn
your television and Apex DT250 receiver on.
Push
the "Menu" button on the Apex DT250 remote control.
Press
the remote's "Up" and "Down" buttons to scroll through the
menu options. Stop when "Parental Controls" is highlighted. Press the
"Right" button to select this option.
Enter
your four-digit password. If you have not set your password, use the default
code of "0000."
Use
the "Up" and "Down" arrows to change or set the parental
control movie ratings. You can select from "None," "G,"
"PG," "PG-13," "R," "NC-17" and
"X." Once your setting is highlighted, press the "Right"
button to go to the next screen.
Use the "Up" and "Down" arrows to change or set the parental control TV ratings. You can select from "None," "TV-Y," "TV-Y7," "TV-G," "TV-PG," "TV-14" and "TV-MA." Once your desired setting is highlighted, press the "OK" button to save your settings. Once the settings are saved, you will be taken back to the main menu. Press the "Exit" key to exit the main menu.
