Microsoft Windows Vista Ultimate Edition Logo
Anonymous Posted on Nov 22, 2009
I'm thinking about upgrading to Windows 7. What should I know before I do it? Is it just to install and use at once, like upgrading any other programme? Thanks in advance.
Anonymous
Level 3:
  • Master 591 Answers
  • Posted on Nov 22, 2009
Anonymous
Master
Level 3:
Answers
591
Questions
Helped
160064
Points
1421
Download the Upgrade Advisor for Win7, and (if your system will support) ... go ahead and upgrade. Be advised that some of your things like monitors, printers, sound cards, etc may complain, so it might be a good idea to uninstall these things prior to upgrading. Once the Upgrade is done it is done, and is MOST difficult to undo, so think long n hard before upgrading.
Anonymous
Level 3:
Genius:
  • Master 1,752 Answers
Anonymous
Master
Level 3:
Genius:
Answers
1752
Questions
0
Helped
343480
Points
5191
If you have a legal copy of Vista, then you can install and upgrade in place. Otherwise, you have to save all your documents and files, format your C: drive, and install from scratch.
Testimonial: "Really helpful!"
1helpful
3answers
Can we undo window 7 anytime upgrade
no once you have upgraded, it cannot be degraded to the previous version. and do you think this will solve the issue? you had the same problem even before with windows 7 home basic genuine version,then how could you think about this problem.let me tell you that genuine or piracy version of windows does not harm the machine but it is *********** board which is creating problem.this symptom "sudden shutdown" suggests that you need to change *********** board if it is not repairable.
tip
Upgrade Windows XP to Windows 7 - it can be done!
Windows XP has been around for over 12 years. With that much time in use, there are bound to be situations where exporting data, finding install disks, installing the new OS, reinstalling the program and then restoring the data is not a viable option or is doomed to fail. What can you do if you are faced with this situation? Simply, upgrade the system to Windows 7!
Despite Microsoft's claim that there is no upgrade path from Windows XP to Windows 7, there is a way to make this happen. As a consultant, I am faced with this issue several times a month and fully expect this to rise as more companies transition to Windows 7. The reasons to upgrade the existing system range from legacy databases that cannot easily be exported and imported, software that is permanently associated with the specific PC hardware and software that require a hardware dongle that does not work with newer PC's. Regardless of the reason, there is a way to upgrade Windows XP to Windows 7.
Let me say at this point that the process to upgrade Windows XP to Windows 7 is involved and there are some things you will need to prepare for to make this process successful. If you have Windows XP 64 bit, you can upgrade to Windows 7 64 bit. If you have Windows XP 32 bit (as most installs are), you will have to use Windows 7 32 bit.
Tools you will need:
1. Download Windows Upgrade Advisor
2. External hard drive
3. Windows Vista Business Edition Service Pack 1 (no license needed)
4. Windows 7 Professional with license
The Prep:
As with any major change, you need to create a backup of the existing system. Use your favorite method of backing up the OS, data and system settings (I prefer to use Ghost to get an entire image of the hard drive in a short period of time).
Create the backup of Windows XP:
Before continuing, disconnect all hardware from the PC and uninstall all printers, scanners and any other hardware devices that will need a new Windows 7 driver. This step will save you time troubleshooting a failed device once Windows 7 is installed.
Also, verify the Administrator account log in and password or setup a new local Administrator level user login and password.
Run Windows Upgrade Advisor. This will indicate if there are any software or hardware that is currently in use that absolutely will NOT work with Windows 7. Evaluate all non-compatible software and hardware issue with the user and see if this is a "show stopper".
You can still proceed with the upgrade and see if you can make the software or hardware to work by changing the compatibility settings in Windows 7.
The Process:
With Windows XP running, put the Windows Vista Business disk in and start the upgrade process. When prompted, choose UPGRADE. (This process can take some time so be patient.) Let this finish and the system will reboot. Verify Windows Vista is properly installed by logging in using the local Administrator account.
Reboot Windows Vista at least 2 times, logging in each time, to ensure the new OS is working correctly.
With Windows Vista running, insert the Windows 7 disk and start the upgrade process. Choose the UPGRADE option again and let this complete (again, this will take some time so be patient). Once Windows 7 is installed, the system will reboot. Use the local Administrator account to login and test the OS to ensure it installed properly.
Test everything:
Test everything - log into each program and verify access and functionality. Do not skimp on this step - get the user to log in and watch them run their programs.
Once initial testing is complete, re-install the printers, scanners and other hardware that will need updated drivers to work correctly.
I have followed these steps numerous times and it has worked perfectly each time. Removing the printers and hardware before upgrading will save you time and was a lesson I learned after my first upgrade.
tip
Upgrade Windows XP to Windows 7 - it is possible!
The Prep:
The Process:
Test everything:
5helpful
2answers
AFTER INSTALLATION THERE'S NO SOUND in windows seven
Did you run the windows 7 upgrade advisor before upgrading to win 7?
I am asking you this because in most of the cases when the drivers are not available in win 7 then that wizard helps you knowing it. You might have to reinstall the drivers once again because the drivers are not installed automatically in win 7 installation, they need to be installed explicitly.
8helpful
I have a Lenovo Y550…before upgrading from Vista (64bit) to Window 7; the Windows upgrade advisor recommended I uninstall OneKey Recovery 6.0 because it wasn’t compatible with windows 7, so I did. After...
I think i know what happened. Windows Upgrade Advisor by the name itself it means that there has to be an older version present on teh system to be UPGRADED. Have you tried installing WIN7 with OKR v6.0 then downloading OKR v7.0 try not uninstalling the OKR v6.0
>I chose not to charge you for rhis since this is more of a suggestion than a resolution... i would like to know what happened after trying this, i would greatly appreciate your comment on this, thanks!
1helpful
4answers
How to install windows 7?
Insert the cd boot from cd and follow the given instructions
After upgrading my pc to Windows 7,my webcam is not working
Windows 7 requires you to re-install all software once you upgrade to it. Windows 7 performs a clean install and all formaer programs are eliminated if they were aftermarket and some that were pre-installed.
I upgraded to windows 7 but it doesn't want to install the drivers. I think there's no drivers for windows 7 ultimate x86.
when we install oparating system then install same oparating systems supporting driver.you must be install windows 7 support all hardware driver.you get support this web side.
2answers
Need to know how to get the windows 7 upgrade
I would suggest going to the store where you bought the computer and ask them how they do it.
Alternatively, you can go to the Acer home page and there should be instructions for upgrading.
Want to know if I can update my acer aspire 4530 notebook from Windows Vista Home Premium to Windows 7 when it becomes available. Not talking about an upgrade but rather a full install of the product. I...
I would recommend you do a clean install on Windows 7 ie. format the hard disk etc. You can purchase a Windows 7 upgrade CD (which is cheaper to change to Windows 7) but you need the Vista CD to be able to install Windows 7.
If Microsoft has done their job properly you should not have any trouble.
I install the Windows 7 Release Canadidate version, this is the last Beta version before the final release on Oct 09 and I have found no problems with this install apart from some device drivers, but this should be resolved by then, either by Microsoft or the manufacturers of the devices.
Based on this I don't think you need to worry.
Top Microsoft Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
