Hi , dishwasher sounds like its filling and draining ok, but washing at all, any help ,
cheers
tony
The dishwasher should heat the water to about 55 C as the heating cycle starts.
In these cycle, the dishwasher pauses after has filled with water and wait for the water to reach the temperature.
If the water isn't being heated (because of a problem with the heating element or thermostat), after the unit stops at the heating cycle, it never continues.
Another possible reason is that the timer unit is defective.
If you have observed anything different post a comment.
If you have lost your user manual, it can be downloaded from this link and follow given operating sequence: http://www.usersmanualguide.com/zanussi/...
Its important to ensure that the spray arms can rotate freely (not truncated by dishes or something else when you load dishwasher)
sorry i mean not washing
hi thanx for reply, it seems to do everything except wash, it looks like it go's through the drying cycle because its very steamy when its finished its cycle, and when it starts, you can hear the pump drsining the water and then the filling starts, and thats it, the timer unit moves around as usual through the cycle, then it drains and fills again, and the timer continues through the rest of its cycle, but with no washing,,,,
thanx
tony
also maybe it is only letting a lesser amount of water into it
thanx, i've actually run it with no baskets in it , so its on its own, but still nothing,,,,,
