Ok i have an rca opal 4gb M4304-A i unwraped it charged a little over the recomended 3 hours plugged it in and put music on it listened to 1 song and turned it off now it wont turn on wont reset and it doesnt connect to a computer..wth am i suposed to do here
Wow, I didn't realize so many people were having the same problem I was having. First try re-installing the firmware for it. Since your computer won't recognize it you will need to download the software, then you will have 2 boxes pop up. One is the install instructions and the other is the actual program install. You will have to hold down the play button on your player while you plug it into the computer. DO NOT RELEASE THE BUTTON UNTIL THE PROGRAM SAYS "INITIALIZING".
It should work fine once you do this. I spent 3 hours going through RCA's website before I came across this step.
hey, i got one too and for some reason mine dosen,t play video's? do you know whats happening?
http://www.rcaaudiovideo.com/support/?kw... has most of the answers for this modelissues. it can only play videos if using rca easy rip!!
I know with mine it won't charge with the wall charger. We have a plug that lets us use the USB charger and charge it through the car. It works then.
My RCA Opal m4304-A not working. If i OPEN my RCA OPAL they become says that ''Profiling requires 20MB Free Space. Shutting down!''
I don't know what will happened?
how to comeback to the normal? please send your suggestions, comments, and helps so that they back in the normal.
thanks. god bless...
I had my RCA tablet pluvged into the wall then I plugged it into a computer charger now it wont charge reset or even turn on what do I do?
