SOURCE: How do I hook up a amp to a Superstar 121 cb radio
first if must be adjusted for deadkey to be lowered down from 1-4watts as not to hurt the amplifier, then connect a small jumper to the amp, run heavy gauge wires to a good power source hopefully the battery.. just use a relay to switch on/off w/key/stereo circuit to turn main power off the the amp. if need too. Also the SWR's must be low have them checked. Free @ any Good Radio Shop.
SOURCE: superstar 121 has only 50%
Some people say cut off or jump the mod regulator on the circuit board. It would be better to get the specs on the circuit and using a small to screw driver (with power off) to turn it up counter clockwise all the way. It is factory set at 50 to 90% modulation. I would not turn it up all the way unless the radio has a mic power output adjustment on the panel. This way if you go "over mod" you can cut back the power. Many "S" meters will also show modulation so you can see if it is too high (into the red). Check for response to modulation before starting to see if it reads modulation. Afterwords to check, key the mic without making any sounds and see where the meter sits. Then whistle into the mic to see the meter moves up. If nothing happens it could be: 1) the "S" meter does not show modulation, or 2) you turned the adjustment in the wrong direction. If no one answers your calls it would be #2.
