I believe the jacuzzi pump impeller has a locking screw directly in the middle of the impeller. You'll have to turn it clockwise to remove it. Then you'll need to remove the cover from the back of the motor using a 1/4" nut driver. Depending on the motor, you should be able to use a 7/16" open end wrench to hold the motor shaft from turning as you turn the impeller counter-clockwise to remove it. Some motors are different, some have a keyed shaft or require a special tool to hold the shaft while the impeller is removed. Hope this helps.
