Pls help me.. i just bought this chunghop universal remote control and when i got home i just found out that the users manual is not inside. i need the code for my tcl tv.
thanks
POLYTRON CODE PLS.?
Yes, i got a chunghop remote RM-88E and i dont have codes, Can anyone please help me.. I have an SHARP television and need codes..
HELP chunghop rm-88E dont work on my sharp primo 14V-70LM
Press and hold set and then press TV. Press the volume up several times (each time the code number increases by one) until the volume on your TV changes.Press set again and it should work. This works for RM-88E at least.
Hello, all,
Its simple to rectify problems with the chunghop universal remote using the codes and if your brand name is not listed then your new remote can learn from the individual remotes for each item ie TV, DVD VCR etc. This will only work if you still have the old one and your new remote is a learing one.
On the new remote select the appliance eg TV, VCR etc. Push the set button until the word 'CODE' appears, then using the arrow keys select the word 'LEARN' , press 'OK' Point new remote at old remote (facing each other front on) press the 'Power' key on new remote and the words 'IR IN' will appear on LCD screen, then while still pointing the old and new remotes at each other press the 'Power or On/off' switch of your old remote and the word 'OK' should appear on new remote LCD screen. then press the 'set' button on new remote. This should complete the action and you should be able to use the power button on the new remote to switch off or on your TV. You will need to repeat this sequence for each function on the new remote ie. volume, channel selection etc. A bit long winded but it works.
Regards
Cheesyknight
Here are the codes for TCL TV on the Chunghop universal remote: 051 053 068 071 073 082 083 084 085 110 111 144 156 199 209 216
When I tried it on my TCL TV, it finally worked on code 216
My tv has no code so i have to do the manual search and i forgot to do it...how do you do it again?
Use a manual from this site
Chunghop RM 139EX
Kode remot polytron CHUNGHOP RM-Q68GS
Follow this link...
http://www.chunghop.com/en/products_view.asp
and download the instruction, seen at the bottom page., it's a .rar file, so you need to Dl winrar before u can read the instructions.
Hope this helps.
I just bought a chunghop universal remote, but i lost the code. please help me, my tv is a jvc
thanks,
Have a chunghop universal & cannot tune to my Sony amp/tuner even though I have the codes with the instructions ?? Any Ideas?? I have tuned it with no problems to my Sharp TV though !! ??
Yes, i got a chunghop remote RM-88E and i dont have codes, its taking me forever to search the web. Can anyone please help me.. I have an RCA television and need codes..
thank you
i had a problem i lose the code 4 my goldstar tv.can u hep me please?
Need help for the chunghop remote control . my tv is sony what is the code?
a few weeks after i bought my chunghop remote control (model RM-033E), i lost the manual and i dont know the code for my Sanyo tv. How or where can i find the codes?
me too. i need the codes. where can i find it? chungchop rm-88e
Hello can anyone please help me??? i have a crapy tevion / medion crt tv and a new chunghop RM -L936 uni remote ,and need codes can any one plese help this very annoyed old fella YOU CAN email me at ,[email protected]
i have the same problem... my TCL tv's brand model is TCL-2909. Please help. all the codes in the manual does not work.
i just bought this remote model and i need the code for Sharp SV-2588S(BK)
