Press MENU button. Use Function Button arrows to bring up the camera icon at top of screen. Use Function Button up or down arrows to get to Date Stamp heading on screen. Press right arrow to get Date or Date and Time. Select OFF Press Menu Done
1. Press the menu/set button. This will bring up a menu. 2. Press arrow left (the button left of the menu/set button). 3. Press arrow down (the button below the menu/set button). This will select the setup menu (so, a wrench icon should be brighter than an icon of a camera). 4. Press arrow up or down (these buttons are above and below the menu/set button respectively) to highlight clock set. 5. When clock set is highlighted press the right arrow button (button right of the menu/set button). 6. Press right or left to select what settings you want to change. 7. Press up or down to get numbers according as you want them. 8. Repeat 6. and 7. as desired. 9. Press menu/set several times to exit menu options.
Press the HOME button to get the main menu. Touch the wrench-and-screwdriver function area to enter the Setup menu. Touch the down-arrow function area until you see the "Date" option. Touch the calendar icon function area to enter the Date menu. Touch the left-arrow function area to select "Set date." Touch the left/right-arrow function areas to select the digit, the up/down-arrow function areas to change. Press the Menu/OK button to confirm the changes.
Step#1: Turn on power, press the left and right arrow buttonssimultaneously,, release both buttons then press the online button to get intothe DIAG. Menu
Step#2: Press the down arrow button twice the operator panel willdisplay Diag.Menu
Adjustment
Step#3: Press the right arrow button the operator panel will displayAdjustment
DC131 NVM R/W
Step#4: Press the down arrow button the operator panel will readAdjustment
DC132 Set Serial
Step#5: Press the right button the operator panel will read SerialNumber XXX Record this serial number
SYS1: XXXXXX
Step#6: Press the Down Button 24 times. The operator panel should readDC132 Set Serial
Target PWA SYS1
Step#7: Press the Select button
Operator display Enter Serial No. 000000 Enter the serial number thatyou recorded in step#5
Action:
Please reference this photo as a reference for the up, down, left, andright keys, when performing the following procedure.
Adjustment
DC131 NVM R/W
DC132 Set Serial
SYS1: XXXXXX
Target PWA SYS1
Step #8: Press the select button operator display Re- Enter Serialnumber XXXXXX enter the serial number from step #5 again. Press Select
Step #9: The operator panel will displa
Note: The Operator will now display "DC132 Set Serial NumberCompleted".
Step #10: Press the left and right arrow button, release both buttonsthen press on-line button to get into the Diag MODE
Step #11: The operator panel will display Exit Diagnostics
Incomplete Exit
Step#12: Press the down arrow button the operator panel will read ExitDiagnostics
Complete Exit
Step #13: Press the select button the operator panel reads Complete Exit
If OK Press SEL
Step #14: Press the select button the operator will read Please Reboot
Printer (103-208)
--Power the unit OFF Wait three seconds then power the unit back ON.Operation is now complete.--
Finalising a disc enables the disc to be played on any other compatible machine. By doing this it changes the disc format so that you can no longer record to it turning it into a Play Only disc. On your Panasonic DVD Recorder you can record to many (if not all depending on the model) of the following DVD Disc formats to the limit of their capacity over multiple occasions. The disc in question can be played back and recorded to on the DVD Recorder during this time but until it is finalised it will not work on any other machine. DVD Formats: DVD-R, DVD-RW, DVD-RAM, DVD+R, DVD+RW. How do I Finalise my disc?
When you have finished the initial recording stop the disc and press the ~FUNCTIONS~button.
Using the ~UP, DOWN, LEFT, RIGHT arrows~ on the keypad select "To Others" and press~ENTER~.
Using the ~UP, DOWN, LEFT, RIGHT arrows~ on the keypad Scroll down to "DISC MANAGEMENT" and press ~ENTER~.
When the disc management screen opens you need to use the ~UP, DOWN, LEFT, RIGHT arrows~ on the keypad to scroll down to "FINALIZE" and press ~ENTER~.
Using the ~UP, DOWN, LEFT, RIGHT arrows~ on the keypad select "YES" and press~ENTER~.
Using the ~UP, DOWN, LEFT, RIGHT arrows~ on the keypad select "START" to begin finalizing the disc, please note by pressing start here you will no longer be able to record or edit the disc being finalized.
Finalizing may take up to 15 minutes. Do not disconnect the mains power in this time. A message appears when finalizing is finished, press the enter button when this appears. It will now play on other compatible machines.
Go to "Menu" and right arrow over to the Tools icon. Arrow down to "Volume" and use the "Function Set" button to select. Arrow down to "Startup Volume" and use your left and right arrows to select the desired volume. Then press "Menu" twice to save and exit.
Press functions button on r/c,use up/down arrow to select delete,using left/right arrow select title to delete,press enter,use left/right arrow to select delete and press enter
An easier way to do this is to just press the right-hand button on the round wheel surrounding the set button. This allows you to scroll through all the various record modes: Snapshot, Bestshot, Video, & Microphone.
You can't do it in the "simple" mode. But if you pick a scene, you can turn on the "Burst" function. 1)push menu/set button 2)arrow down to second tab (picture of camera) 3)arrow right to allow you to scroll down list to burst function and change to "on"
