My Hobart lx18 Dishwasher fills up intermittenly . Upon power up
water solenoid gets power for 5 Sec then shuts off (Checked with meter). I have cleaned water level probes, same problem. I also tryed disconecting the rear probe same problem. I am thinking controle panel or relay? Thanks Frank
Frank,does the sump probe (the one underneath the screen) look good?It should have at least one quarter inch of metal.I have seen these break and its hard to tell but the info your describing sounds like that probe is bad or the control board.I'm a hobart tech and can help you troubleshoot,let me know----Tony
A Dishwasher is a high quality product that focuses on energy
efficiency. In addition to saving money on electrical use over other
machines, they use less water than the average dishwasher. When your
Dishwasher is not filling with water properly, before you call for
a service appointment, check the components yourself.
Machine will fill for several seconds only. Have shut in down and started up several times but problem persists. Water level will not reach any of the probes. Any suggestions would be greatly appreciated. Thank you
