Question about Kyocera CS-2550 Black and White Copier
Blank copy - Kyocera CS-2550 Black and White Copier
    President:
  • Kyocera Master
  • 1,449 Answers
Please check corona wire may be it was broken re-wear it then print ok
Posted on Nov 22, 2009
  • Tareq Bin Mostaq Mostaq
    When we get a blank copy this photocopier,then we check this items or some reason.
    1. First time we check corona wire,its ok then follow next step or not ok then change it.
    2. check drum charging grid its ok then we can a get decision high voltage is damage,change or repair ti by a service technician
    New Friend:
  • 165 Answers
1 no coronas in this copier
2 no charge will give u solid black copy
check transfer or drum possibly not turning
Posted on Mar 28, 2010
6ya staff
SOURCE:
I have a Canon NP 7130F which prints out only blank paper
check cartridge setting how-
check all spring on correct place
check ITR spring touch point
check printer to cartridge touch point
Apr 01, 2014 | Canon NP 7130 Black and White Copier
HP CM2320 MFP blank pages come out with printout
Hi my hp cm2320 nf prints normally and prints when you press the color copy button. But it will printout only blank page swhen you copy black&white. You press the black&white copy button only blank pages come out. Any help
Lang Dibba, Gambia
Jan 30, 2012 | HP Laserjet CM2320nf All-In-One Color...
Trying to copy a DVD--when I insert a blank DVD, it spits it out and asks me to insert another. I have tried with two different blank DVDs, and each time it spits it out without copying, and asks to...
1. your DVD blank may be rejected due to the program compatibility.
2. the DVD that is being copied was burn at a certain speed and this may have an affect on the
copy of the original.
3. the blank DVD should have the same capacity as the original or better that is if the
DVD blank has the capacity of 4.5 GB and the original is 8.5 GB then the copy has
reached it's capacity and will be ejected by the DVD burner.
I hope this helps. Have a great day.
Oct 05, 2010 | Sonic RecordNow! Deluxe 7.3
Blank copies on brand new Toshiba e-Studio 120
Did you pull the plastic tape off of the toner cart?
Feb 18, 2010 | Toshiba e-Studio120 Copier
Top load copies are blank
I tried changing the the size to a reduction. It took the sheet from the top and copied it at a reduced size with no problem. Then I switched back to normal size and it worked just fine. I would have never thought to try a different size without your suggestion. Thanks for the help
Randy
Jul 17, 2009 | Sharp Office Equipment & Supplies
Blank copies
see the cartridge do is good installed.
Remove the cartridge and putt it again.
If the problem do not go away please try with other cartridge.
Or if the printer is ink-jet printer and you have not used it for some time than the ink can be stuck
Jul 16, 2009 | Office Equipment & Supplies
Copier is not copying
possible broken charging wires (corona wires) (chargeing wire) no charge on the drum will not pull developer or broken (transfer wire) will not pull image off drum resulting in blank copy
Dec 19, 2008 | Office Equipment & Supplies
KONICA 7020 - Blank copy
I have never heard of a developer moving backwards!!!!!!!!!!!!!!!!???
the motor that runs it, the .... there is too much involved to mention. A developper moving backwards will spill so much toner in the machine anyway.
If you get a copy and then it goes blank, that tells me you have a problem with the SEPERATION UNIT, it may be shorting out causing the paper to rise against the drum giving you blank copies.
A blurr copy tells me there is a problem with the Scanner/Optics area. maybe the rails that the scanner run on are too dry or has a problem, the optics(mirrors) may be misaligned.
Not sure what you mean by (hanging) ??
Jul 31, 2008 | Office Equipment & Supplies
Workcenter xd103f copy comes out blank
Which cartridge did you change? If its the toner cartridge, make sure none of the packaging materal is left on it, same with the drum cartridge. First and simply remove and reseat the cartridges.
What I suspect with the blank copies is a broken transfer corotron wire.
Open the right side door. On the bottom you will see some whit plastic rollers. Above that you will see an opening about 1/2 inch wide. There is a very thin wire in that channel. That wire has probably broken causing your blank copies, I highly suspect that is broken.. That wire when it is dirty also causes really poor copy quality.
Also clean all the mirrors and glass well. That will cause poor copy quaility issues.
Mar 12, 2008 | Xerox WorkCentre XD103F All-In-One Laser...
Kyocera CS-2550 Black and White Copier Logo
133 people viewed this question
Top Kyocera Office Equipment & Supplies Experts
Tareq Bin Mostaq...
Tareq Bin Mostaq...
CheckitRight
CheckitRight
Marvin
Marvin
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
