Sony Xplod 1100 Watt Max 10" Subwoofer, XS-L100P5W Car Speaker Logo
Posted on Nov 21, 2009
How do i get to the voice coil in my 10" xplod? im pretty sure its blown but i wanna take a look.
Anonymous
Level 1:
New Friend:
  • Contributor 4 Answers
  • Posted on Nov 21, 2009
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
901
Points
8
Its behind the magnet but you cant replace just the voice coil you need a whole new speaker
1helpful
2answers
How do I connect a Sony xplod 1000 watt 2 channel amp to 1 10" dual 4 ohm voice coil 1500 watt planet audio subwoofer?
Connect one voice coil to one channel of the amp. Repeat with the other voice coil. Do not bridge the amp as your only choices would be series which would be an 8 ohm final load and cuts the amp power in half or parallel wiring which results in a 2 ohm load and very few Sony amps currently made can handle being bridged to a 2 ohm load.
Are sony xplod 1100 watt 10'' subs 2 ohm stable
No keep on trying end blow everry thing up, Buy some real subs.
1helpful
I have two 10inch cvr kickers running off of a 2 channel 800w sony xplod amplifier...everything worked fine for about 3 months until my subwoofers just stopped playing sound..out of curiousty i opened my...
  • Yea, you blew the voice coil. Pressing on the cone where you are is hitting the spot that is making the coil connect again. Just like a shorted wire. Sometimes you can bend it and get a connection. You are gonna have to replace the sub.
  • If you have any comments please feel free to leave them here.
  • Hope this helps and thank you for using FixYa.
Regards, Tony
1helpful
How can i tell if a dual voice coil alpine type x is blown, apparently it was only wired in and only one voice coil was hooked up?
they best way to do this is with a multi meter on the OHMS setting.... to do this set the multi meter to the least ohms setting, usually it reads 20 or under. Connect the wires to each voice coil (by the speaker wire connections) if the multi meter reads 2 to 4 ohms whichever your speaker is, then the voice coil is not blown, but if it reads 8-10-12-14 or OL which means open loop then the coil in junk.
Can i have box dimentions for my 12" xplod sub
  • Warranty Terms - Parts 1 year limited
  • Warranty Terms - Labor 1 year limited
  • Product Height 12"
  • Product Width 12"
  • Product Weight 7.8 lbs.
  • Product Depth 6-1/2"
  • Subwoofer Size 12"
  • Resistance (Ohms) 4 ohms
  • Bottom Mount Depth (inches) 10"
  • Woofer Composition Mica-reinforced woven glass fiber composite
  • Woofer Surround Rubber
  • Peak Power handling 1300W
  • RMS Power Range (Watts) 380
  • Cutout Diameter or Length (inches) 12"
  • Sensitivity 84dB
  • Frequency Response 30Hz - 1kHz
  • found at:::---- http://www.bestbuy.com/site/Sony+-+Xplod+12%22+Single-Voice-Coil+4-Ohm+Subwoofer/9202481.p?id=1218057724056&skuId=9202481
I wired my alpine sws-1243d and in a matter of 3 minutes it burned up now the speaker wont even turn on so dont know if its blown or what but im getting no sound whatsoever from the woofer i wired positive...
The polarity of speaker connections verses the connection to the amp should have nothing to do with situation. The sound reiforcement would be weaker in one direction is all.
Make sure the amp was not rated for more power than your speakers. If you overdrove the speakers you may have fried the voice coils.
1helpful
Hi ive just bought a 2nd hand sub n amp,wired them up and i can only get the amp 2 work,my other subs work plugged into the same amp just to check but the xplod wont,im not getting anything wot so ever,i...
Hello empsglen,
If the sub voice coil is open, you will get exactly no sound. No crackling, nothing.
Use a multimeter to check the sub voice coil. If the meter reads infinity, the coil is open and to the amp, it's as if there's no sub connected, and you will need to replace it.
Hope this helps.
2helpful
2answers
I have 1000 watt sony XPLOD amp and i just installed it today. with new monster cable&ground. the green light turns on& thumping goes for a little. i try to raise up just a little bit& after 2...
it isnt getting enough power and its tripping the internal switch on the amp and putting it in safe mode. either your wire isnt a high enough gauge. you might need a capacitor or you need bigger wire.
1helpful
What size is the voice coil in my 1100w 10" sony xplod sub?
go to the sony website or any dealer website and look at the model number of your sub, punch that in and get the measurement.. mostly gonna be inches.. but then go to google and convert it to mm
Top Sony Car Audio & Video Experts
xxxxxx xxx
ZJ Limited
ZJ Limited
 Grubhead
Grubhead
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
