blurry can be due to out of focus or camera shake are the most common if you are in video mode try turning off Auto focus and using manual or the other way around , next if the image is blurry while in close up mode when does the image become clear again ? what adjustments are necessary to get a sharp image ? moving the camera further away ? change settings ? add more light ? does your camera have a setting called MACRO ? It seems your device has the capabilities to shoot clear video close up so let me know if anything I have suggested worked or was of no help .
The camera is having problems focusing. Try focusing on a bright object hold the shutter button half way down to lock the focus then frame your image and press the shutter to take the photo. If this does not work then try manual focus.
It is common for binoculars to have one independently focusable eyepiece. If one eyepiece can be rotated, then that is the case.
If that is the case, focus through the one that DOES NOT rotate using the center control until you get a sharp image on that side. Then rotate the eyepiece on the blurry side until the blurry side is sharp. If you succeed at this, from henceforth the center control will focus both eyes adequately
Normally this problem is caused by incorrect setting of the dioptre. This is a "focus" ring on the eyepeice which adjusts for the strength and position of the eye. Try adjusting this for best focus at about 5-10metres prior to focusing the unit.
Is your shutter speed fast enough? If not, you'll need a faster shutter speed or a tripod.
Are you using the proper focus sensor? Is the entire image blurry or just portions of it?
What happens if you focus manually? If it comes out sharp, then there's a problem either with the lens or the autofocus system on the camera. Have you tried it with a different lens?
When operating any digital camera, the camera tries to capture the best focus and exposure for that particular scene. By pressing the shutter button half-way down, the focus and exposure is being set. There will be a green circle on the upper left hand corner of the screen, then your camera is ready to take the picture. Slowly depress the shutter the rest of the way down to take the picture.
Also try to reset the camera back to factory defaults as there could be a setting that is causing the images to be blurry. To reset the camera - have the camera in shooting mode - go to Menu - left arrow to reset and press ok. Highlight yes and press ok. This will reset the camera back to factory settings. See if this clears up the blurry images.
There is a focus ring around the lens of the WEB cam turn this ring until your image becomes clear, just like a camera focus knob.
Click on the WEB cam software, you will be able to go into an options or configuration, click on video setting, you should see an image of yourself, adjust the focus until the image is clear.
To me it sounds as if the driver ya using isnot the best.. try Uninstalling and reinstalling any and ALL software & Drivers. Try another testing program, get Amcap, Google it. OR maybe the Focus ring has been moved? tho thats not gonna fix sound.. OR maybe the camera is going faulty?
