I Got it!
I finally got my HTC TyTN II yesterday from Dubai.
First thing I wanted to test was the GPS. It did not work with: TomTom6, Google Maps, Yahoo Go.)
I was surfing around to find something that would help me out and have noticed that many people have the same problem.
Many people (Like me) did not know howe to setup the GPS.
Many people are saying: "You have to put it your GPS settings in Com 4 and the Baud rate on 4800 and it should work.
Well mine didn't work with those settings. (Along with other people.)
I had played with the External GPS option (Don't do this cause setting something wrongm ay cost you a
HARD-Reset.)
I Was lucky that mine worked again after a
SOFT-Reset. So watch out!
The standard GPS settings! (If you have changed it, Soft-reset your phone and set it up as these pictures show.)
Why am I doing this?People buy this phone to make use of it. When something does not work why buy the phone then :S
Hope that this may help a lot of people on here and other forums, communitys & websites.
Here is my story of how I did get my GPS to work:
1. Download the GPS addresses by using QuickGPS (Start -> Programs -> QuickGPS).
(This will download info of what your GPS Reciver needs to connect to the satalites.)
2. Download a free (Well half free, You can also buy this application it will give you some extra options, but we don't need those extra options.) tool named: GPS Test. (
http://www.smartphone.net/software_detail.asp?id=3170 or at
http://www.pocketpc-software-downloads.com/software/t-free-pocketpc-gps-test-download-uykfcoyy.html)
(This program will scan all your mobiles com ports and Baud rates, To see what your real GPS settings are.
In my case they were: COM PORT: 4 - Baud Rate: 9600 (Notice it ain't 4800. Usaly it shows your settings with a pop-up.
When It doesn't Go to "Menu -> GPS Settings", There it will show you you're GPS settings.)
3. Install TomTom 64. Download your free map.
5. Go to the GPS settings.
(Set-up: Other NMEA GPS-Reciver -> GPS-Baud Rate -> Com. (Select the Baud rate + Com port from what the GPS Test did show you.)
6. Now wait.
Thanks for your comment RJ.
The Mio P350 has an internal GPS and no fire wall separates them as far as I am aware. There is certainly no mention of a fire wall in the user manual.
Cheers
Tom
Cheers
Tom
