Can i have the t v sound coming out of the home theatre system without the d v d playing
On the back of the TV there should be an audio out port for an RCA style jack, and an auxiliary input on the back of the DVD player. You have to change the input source on the DVD player, but this usually woks just fine.
As most home theatre systems offer no analogue audio input and only use the audio coming from the dvd being played the short answer is no.
If your home theatre system has a digital input and the tv has the corresponding output then yes you could me able to connect the two. Otherwise you could try to get hold of a analogue to digital converter and convert the tv's audio out to digital.
Sony® created BRAVIA® Theatre Sync™ to go beyond basic digital audio and video transmission. Based on the HDMI-CEC function, BRAVIA® Theatre Sync™ will be included on select BRAVIA® Theatre home A/V systems and components. This useful function reduces the hassle and time consuming job of powering up, routing signals, etc. to the simple push of one button.8 Want to play your DVD on your Sony® A/V system? Easy, just push PLAY on the BRAVIA® HDTV remote and everything is taken care of for you. Even when the system is off! Want to change from TV sound to digital surround sound through your Sony BRAVIA® Theatre A/V system? Just one push of the Theater Sound button on the remote and voila, surround sound through your system. Want to power down everything once you've finished enjoying it? Push one button and the TV and A/V system powers down. BRAVIA® Theatre Sync™ helps make things a whole lot easier to operate.
"home theatre system has a digital input and the tv has the corresponding output then yes you could me able to connect the two"
how do i do this? i've tried with RCA cables (those are the red and white ones, right?) from the AUDIO OUT on my TV to my AUX IN on my home theatre and this does not work. is there a setting on my tv that i need to change to make it work? when i have the samsung home theatre set to AUX 1 or 2 it just turns the actual TV speakers on, and when i have it set to DIGITAL IN i get no sound whatsoever. is this because i have an HDMI running from the TV to the DVD/SOUNDSYSTEM already??? i am so lost
