Master
- Posted on Nov 20, 2009
Re: Oven shows F7 and continues to beep
This almost always requires replacing the touch key panel. Once in a great while you can avoid replacement by disconnecting the ribbon connector from the key panel to the electronic range control and cleaning the end of the ribbon connector with a soft pencil eraser. Good luck.
You have either a stuck button on the control pad or a bad ERC(clock).
Try pushing all the buttons at random several times each. Sometimes you gt lucky and unstick the button.
If that does not work the ERC(clock) will need replacing.
