Question about ASUS T2 P4P8T WO/CD/MDM FM AGP8X GETH WIFI (t2-p)
I installed windows XP on my Asus p4p8t and the sound isn't working anymore...im installing soundmax audio drivers from asus.com but it's saying driver not found or HDA audio bus needed and not found...can anyone help me with this...thanx Visar !
  • Anonymous May 11, 2010
    Do you have a seperate sound card, or are you using the motherboard?
  • 2,229 Answers
I'm thinking that you might have to install the chipset drivers, also.
Because the sound is part of the motherboard, they will be needed.
Posted on Nov 20, 2009
    New Friend:
I have had this problem in the past.The solution is to do a clean reinstall of "windows XP" BUT !!!! before you start, remove the sound card, and the graphics card and any other cards from the motherboard. Reinstall XP. Only then do you reconnect all your cards to the motherboard. Windows will then say "found new hardware", so make sure you have the correct driver discs handy,(download them in advance if you have to) or Windows will just use one of it's own drivers. Guaranteed fix. I have used this technique with lots of different M/B's (XP assumes that anything attached to the motherboard is part of the motherboard, and ignores it's existance). Jim Duffy
Posted on Oct 05, 2015
6ya staff
SOURCE:
Hi.im trying to find a asus p4sc sound driver.any advice please
If your Motherboard is Asus P4SC-EA with chipset SiS651 as is mine, then look for SiS 7012 SoundMax Audio driver, SiS 7012 has variants so be sure to choose SoundMax. Hope this helps.
Nov 04, 2010 | Intel ASUS P4SC Socket 478 Pentium 4...
P5GV-MX Motherboard: have installed windows 7 but having probs with sou...
The following audio driver worked for the ASUS P5GV-MX on Windows 7: SoundMAX HD Audio Driver 6.10.02.6585
I found it a website called "TechSpot" SoundMAX HD Audio Driver6 10 02 6585 and it worked like a champ!!! I spent quite a while looking for this solution so I hope this helps someone out!!
May 16, 2010 | ASUS P5GV-MX Motherboard
ASUS SoundMax install program cannot find AC 97 Audio driver
Click on the Link below this for ur mobo Audio.
http://www.driverstock.com/ASUS-P5VD2-MX-driver-download/6-9-10181-81181/index.html
Download/install./Restart
About ur Speaker all u need to Do is connect the Speaker to other Audio Source like ipod/Zune or any MP3 player.if the Sound Doesnt Come Means the Speaker is Bad.
May 16, 2009 | ASUS Computers & Internet
My motherboard type is ASUS P4S533-MX, driver sound doesn't work, please help me!
Greetings,
Download the driver from the below given link:
http://tinyurl.com/63pydg
From the above link, scroll down to audio section where it says 'SoundMAX Audio Driver version 5.12.01.3665 WHQL for Windows 98/ME/2K/XP' in description and click Global.
Warm Regards,
Zulfir Sadat M
Apr 15, 2009 | ASUS P4S533-MX Motherboard
K8V-X SE Sound Card In xp 64 does not work!
Hi brian_stiver,
click on this Asus link for the K8V-X SE board;
http://support.asus.com/download/download.aspx?modelname=K8V-X%20SE&SLanguage=en-us
You must click the dropdown menu & choose Windows XP!
Than click the Search Button.
DO NOT pick Windows 64bit from the list of operating systems.
Asus list audio driver support for Win64bit here;
SoundMax AD1980/AD1888 Audio Driver version 5.12.2.5280 for Windows 64bit XP/2003.
Download the file named; ad1980_1888_51225280_64bit.zip
Create a folder on your desktop & name it Audio. Save the *.zip file in to your Audio folder. When you uncompress the the *.zip file keep all uncompressed files within your Audio folder.
The reason for keeping all the files within the Audio folder is you may need to install the sound drivers through windows device manager if the audio setup.exe program fails.
Mike
Mar 29, 2009 | ASUS K8V-X SE Motherboard
ASUS K8V-MX SOUND DRIVER PROBLEM
Is the driver the right one? What operating system do you use?
Try disabling/re-enabling the device and/or reinstalling the driver.
Type your model number into the search box on this page:
http://support.asus.com/download/download.aspx?SLanguage=en-us
Download the available audio drivers.
Hope this helps!
Oct 23, 2008 | ASUS K8V-MX Motherboard
Audio driver problem
I hope this link can help you download the right driver for your motherboard.
-mrsolution
Jun 11, 2008 | ASUS K8V-MX Motherboard
How to reinstall my mixer device
When you install the sound driver for you asus P4XP-X the mixer is installed by default. You can down load asus last driver for your P4XP-X, SoundMAX Audio Driver version 5.12.01.3533 (WDM) for Win98/ME/2000/XP.
Click this link to asus. http://support.asus.com/download/download.aspx?SLanguage=en-us
Fill in the three windows to the right of the page.
Motherboard
Socket478
P4XP-X Click search.
Click the + sign next to Audio.
Create a new folder & name it P4XP-X sound driver.
Download file: adiwdm_3533.zip & save in your sound folder.
Uncompress the file: adiwdm_3533.zip.
Install the setup.exe file. No need to uninstall current driver.
The mixer will install it's self down near the clock & also in your control panel.
That's it.
Have more questions? Just ask.
Enjoy!
& please vote...
Mar 07, 2008 | ASUS P4XP-X Motherboard
You should install the Chips drivers or intall all the driver in series listed in your CD Utilities. Its good if you download the latest drivers of your system at www.asus.com or here: http://support.asus.com/download/download.aspx?SLanguage=en-us
You should download for 64x2 drivers.
Jan 07, 2008 | ASUS M2N-MX Motherboard
A8S-X no sound with vista
The latest XP drivers should do the job. Uninstall the drivers that you already installed. Unzip the driver files to a temp directory, then instruct the Found New Hardware wizard to search in the temp directory for drivers, or click on Update Driver through Device Manager then point the Wizard to search in the temp directory: SoundMax ADI1986A Audio Driver V5.12.1.5430 for Windows 2000/XP/2003: http://dlsvr01.asus.com/pub/ASUS/mb/socket939/A8S-X/ADI1986A2000XP.zip
Jul 09, 2007 | ASUS A8S-X Motherboard
ASUS T2 P4P8T WO/CD/MDM FM AGP8X GETH WIFI (t2-p) Logo
1,156 people viewed this question
Top ASUS Televison & Video Experts
Steve Sweetleaf
Steve Sweetleaf
B.Th. Pluijm
B.Th. Pluijm
 Mike M
Mike M
Are you an ASUS Televison and Video Expert? Answer questions, earn points and help others
