Question about Sharp XR-11XC Multimedia Projector
I just changed the bulb in my sharp xr-11xc. it worked fine till i turned it off and now its not working again
  • 2,239 Answers
Reset the lamp timer. hold down the menu, down arrow, and enter buttons, then press power.
Posted on Nov 24, 2009
6ya staff
SOURCE:
Lamp issues
Look at the ballast module. It controls the lamp operation
Nov 30, 2013 | Sharp XR-11XC Bulb/Lamp
Turn on optoma 605 R light flashes but wont stay on fan is running fine.
The problem is: Bulbs wear out. Especially projector bulbs. The operate at high temperature and the filaments break down in time. When they are intermittent (on/off) the filament expands and contracts, and at some point disconnect entirely. It is time to replace the lamp with a new one.
Feb 05, 2018 | Sharp XR-11XC DLP Projector
I have a Sharp XR-11xc and my bulb recently burned out. I ordered and replaced with a new lamp. It would turn on but no light would be projected. I read up on the subject and tried the reset of the lamp by...
I have the exact same problem. I've only reset the counter once though. It worked great at first, but seems to be getting worse. It's like it tries to start, just doesn't light up (maybe not warm enough???) then retries like 5 times until switching to the red light. Unplug and retry.... and eventually it does come on, and once on, all is ok. Is this just the projector trying to slowly 'break in' the new bulb since it has almost no hours?
Apr 21, 2010 | Sharp XR-11XC DLP Projector
My Sharp XR-11XC Projector died not long ago with very few hours of use. The unit will not power up nor does it show any signs of trying to. No LED lights, no fans - nada. I tested the fuse and it's...
I opened mine up hit the red reset in the front and now all good. If ur red light is blinking make sure ur lamp compartment is shut properly, if not the red light will blink and unit won't turn on.
Mar 26, 2010 | Sharp XR-11XC Multimedia Projector
I just replaced the lamp in my xr-11xc sharp projector, reset the timer, and it turned on. after shut down, i tried it again, and now the standby light comes on, i hear the fan spin up, then the lamp...
the colorwheel may be bad. if it doesn't spin, the lamp won't strike. if the colorwheel is ok, replace the power supply/ballast. you can get one and do it yourself, or send it to a sharp service center. either way, try www.avsolutionsny.com. they're really good.
Jan 27, 2010 | Sharp XR-11XC DLP Projector
DO NOT HAVE A USER MANUAL- AHARP XR-11XC MULTIMEDIA DLP
You can download user manual of Sharp XR-11XC from HERE for free as website will ask you any of your email address only.
User manual has all info about this unit.
Feb 12, 2009 | Sharp XR-11XC DLP Projector
Sharp xr-11xc only displays black & white
Sounds like your connection is bad, check ur connections on ur cables
Oct 25, 2008 | Sharp XR-11XC Multimedia Projector
Lamp replacement
Hi traks137
You will have to reset both the lamp and filter timer before it will change the status of this unit.
Your user manual will have all the steps in it on how to do the required resetting.
Thanks for using Fixya !
May 21, 2008 | Sharp XR-11XC Multimedia Projector
424 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
amir hamza
amir hamza
k24674
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
