NorStar T7316E Corded Phone Logo
Posted on Nov 19, 2009
Nortel Voicemail Reset Password Problem
I reset the voicemail password and it should be 0000 but it states that this password is invalid. I've tried several times, can anyone help?
  • terry gormley May 11, 2010
    Did you go into vmail and reset password for that mail box the mailbox number should be the same local number for that phone.If it's not you can't reset password
terry gormley
Level 1:
  • Contributor 52 Answers
  • Posted on Nov 27, 2009
terry gormley
Contributor
Level 1:
Answers
52
Questions
0
Helped
44952
Points
82
You have to make sure this is the wright mail box for that local The mail box should be the same as the local.From the main set press feature 983 password
120000 for 2 digit locals , 1020000 for 3 digit locals etc then press mbox press chg enter mbox no. next password press reset this will take in back to 0000 as mailbox password.
I am unable to unlock my voicemail on my Nortel 7316 phone system
You would need to log in as the voicemail admin using "Feature 983" followed by 102 (if you have 3 digit extension numbers) then the voicemail admin password. From there you can select MBOX and reset the password to 0000 for the mailbox in question.
4helpful
When logging into the voicemail for a Nortel T7316E i get the Mbox Locked warning. I have followed the steps to reset my password and have successfully done that. I then proceed to access my voicemail with...
You're resetting the wrong password. Keep in mind that mailbox numbers and extension numbers are not always the same. When you're resetting the password, make sure that the EXT assigned to it is the right one !! If you're resetting the reception mailbox, it's usually mailbox 100 (regardless of what the extension number is)
My Nortel phone NT8B27JAAE6 has locked me out of the voicemail. Can you tell me how to reset it???? Thanks Agatha
Feature 983 log in is 120000 (if 2 digit extension, 1020000 if 3 digit, 10020000 if 4 digit extensions)
Select Mbox, enter that locked extensions mail box number, You will see password RESET. Select RESET. Release out. This will reset that mail box password to 0000. Use feature 981 on that phone and enter the new default password of 0000. you will then be prompted to change the password.
Feature 985 will show you the extension of the line you are using.
12helpful
2answers
How do we reset a voicemail password for a Nortel M7324 phone?
press feature 983 the screen should say log:
enter 1020000 (default password) if you have a 3 digit intercom number, 120000 if you have a 2 digit intercom number
the display should say mbox, AA, and othr above the three soft keys
press the mbox soft key
the screen should say add, del, and chng above the soft keys
press the chng soft key
enter in the mailbox number you wish to reset the password on
press ok
the screen should say reset and next above the soft keys
press the reset soft key
press the Rls key
your password should be reset to 0000
2helpful
Delete Voicemail
to reset the administrator pasword enter feature 985 press 9, at the password prompt enter 73738767793 (resetsmpwsd) and press ok or #,press yes to reset password. password should be defaulted to 0000. then try Feature 983. if your system has 2 digit intercom #s your password is 120000 if your system has 3 digit intercom #s your password is 1020000.
1helpful
Need to reset my voicemail password without original password
To reset password on any tel set go to main set and press feature 983 this gets you in to programming you need a password and default password is normly
120000 for 2 digit locals and 1020000 for 3 digit locals etc.enter this password and press ok go in to
mbox type in mailbox press change , press reset password. hope this works
1helpful
We lost the voicemail password!
If you have an in-house administrator, they can log in and reset it. You might try 0000 and 1234 just in case, otherwise you will have to call whatever tech help you have and get them to reset it.
9helpful
We have Nortel T7316. I have been locked out of the voicemail admin. I have tried all passwords I can think of but cannot get in. Please help
How do I reset a password on a Norstar Voice Mail mailbox?
Press Feature 983.
Enter the System Coordinator's Mailbox number (default is 12, 102, 1002, depending on length of extension numbers) followed by Password (default 0000).
Press MBOX.
Press CHNG.
Enter the mailbox number that is giving you troubles.
Press RESET. The password has been reset to default (0000).
Good Luck.
5helpful
2answers
T7316E Voicemail Password Issues
Feature 983
password is: 1020000 (if you use 3 difit extensions)
OR
120000 (if you have 2 digit extensions)
My voicemail on my nortel platinum is locked
You need to reset the password .
Feature 983
enter 1020000 as the password if you have a 3 digit extension number or enter 120000 if you have a 2 digit extension
next press the button under the screen with the heading of m box or mail box
next your options are add delete or change
press change .
next enter mail box number
the next step will be to press the reset button
after re-setting the password press the release button . Now open your mail box and enter the default password 0000
Top NorStar Lands Phones Experts
Paul Bade
Daniel Blask
Daniel Blask
Are you a NorStar Lands Phone Expert? Answer questions, earn points and help others
