We have the F1 error code and need to know how to clear it
I've never found personal ranting to work myself. However F1 is meant to be a flood warning, there's a sensor in the bottom of the drawer unit that stops the dishwasher if water accumulates in the casing, not the drawers!
So the error could be caused by a leaky hose, a broken or fouled lid or a blocked drain hose stopping the drawer from pumping out, at least these are the problems I've heard of or had.
TURN THE POWER OFF BEFORE TRYING THE FOLLOWING.
To see if you have water in the unit you need to remove the lower drawer, to do this open the lower drawer and you'll find the drawer release clips on each side of the drawer in the corner to the front and at the bottom. When doing this always support the front of the drawer in one hand while releasing the clips with the other. To release the clip push it in and slide it back 3-4cm while gently lifting the front of the drawer (don't try to lift it out, you only want to make the clip slide back easier!). Repeat this with each clip.
The drawer is on telescopic side rails, so while supporting the front you need to slide each side back, the clips you released are at the end of each rail and you can slide these easily by feeling just under the edge of the drawer. When they're both slid to the back you should find that the drawer will slide further forward and you can lift it out but don't try and pull it right out because all the hoses and wires are connected, just have a towel or something that you can put on the floor to protect the drawer and leave it there.
You should now be able to see into the base of the unit and see if there's water there. The sensor is attached to the bottom panel in the casing, if there's water puddled here you may have a hose or lid leak, you'll need to dry the casing out (thorougly, probably with a hair dryer before you can clear thF1 error on the 1 draw dishwasher - 751d9aa.jpg.
On older models the lid motors on either side of the unit (they were white) did have a reputation for breaking, if you see water splashed around the sides it might be one of these that's gone, check for tell-tale signs for leaky hoses too (that would be water where it's not meant to be).
To replace motors and hoses is up to you.
We have F1 error on both draws. How do we fix it ?
Cut the power for 1 min.
If you insist on keeping this overpriced piece of **** dishwasher that is pretty to look at but floods your floor, then I suggest you buy a second one on ebay or craigs list for parts that someone is throwing out. you certainly wont get any parts from the manufacturer. Regarding the F1 error, your washbasin is flooded. Pull the lower drawer out and find the two twist pins on either side of the drawer. Twist and pull them out and then slide the front of the drawer down and remove it. The entire drawer can now be removed from the rails. the basin is in the bottom of the cabinet. You have to dry it out completely (towel and hair dryer) or the F1 switch will keep coming on. Since you've gone this far, remove the rest of the dishwasher, take it a dumpster, or post it on eBay...you might get $200...so cut your losses now
Mine has come up with the F1 code as well. I'll look at it soon. Don't complain about dish drawers people! They are great in my opinion. I've had mine for 5 years and it's been good til now. And I suspect it flooded due to overloading and having an oven tray on the top to nicely spray water everywhere
Finally got around to repairing the dishwasher.
It started beeping and showing the F1 code again at 1am!
Luckily I woke up as I could hear an arcing noise and could smell burning.
I quickly pulled the drawers out from the cavity and pulled the power
plug. Went back to bed and attacked it the next day when I got home.
To fix I pulled the bottom draw out. Sure enough there was water in there thanks to me stupidly over filling the top draw.
I pulled the black cover that covers the imput power board PCB (grey silver in this thread)
Pulled out the power board PCB and found arcing at the left hand side
where the sensor board PCB is located at right angles to the power PCB
I etched away the burnt arcing carbon track left by the arcing until the colur of the board was normal and not black anymore
Used a soldering iron, flux and solder to re tin the surrounding tracks as some were looking a bit rough.
Reassembled and now it's all fine
So if yers starts with the F1 code and you hear the arcing or smell a
burning smell and you get to cut the power quickly enough, hopefully
you'll be able to sve your power PCB too
Cheers
joelMatthews
Sounds like the rubber on the lid that closes down over the draw may have had a chunk broken. Which will also cause the leak and the F1 error. Pull the draws out and check the lid rubber seal on each draw. I checked mine by running cycles and chcking for leaks after I repaired mine
From the service manual:
IDEman, June 2010 Thank You very much!! Pictures very useful. Repair was a snap. We love our Fisher-Paykel Drawer Dishwasher - very convenient and useful, as with anything today don't expect it to last forever - plastic parts - C'mon. Only one thing to add to the Solution - upon removal of the drawer - I noticed some calcium build up on drawer rim. Hard water I guess. I cleaned it off with soap and a scrub pad - to get a good seal on the lid. Just a little tweak to the solution. Once again I am very greatful and my wife is even more greatful to IDEman. Keep it up.
IDEman's solution worked for me - thanks very much
Hi guys
thanks very much to IDEman for providing those helpful suggestions
i've just had the F1 error as well on both draws as i stupidly put some normal dishwashing liquid in this dishdraw Fisher and Paykel and apparently you are not supposed to do that ROFL......says the wife
anyways after following IDEman's instructions and taking the bottom drawer out and drying it all really well........hair dryer and towels i got the machine going just now and just doing the rinse on top drawer first all is perfectly fine at the moment
thanks very much once again and hope others sort it out this way too
Dino from Sydney :)
I solved this problem simply by turning the unit off and washing my dishes by hand for two weeks and giving the fingers to the unit everytime i walked past it,Seems to be working fine now,Must have dried out? who knows,What a pile of c**p! Tinto From NZ
Question???? where is the impellor located? My unit finally took a crap after 10years. F1 is coming up, I took the bottom drawer out checked for leaks, didn't find any. However, I as I added water to make sure the lines were cleared, some black rubber piece came out the drain line? what the heck???
F1 on both drawers. Removed lower dryed it also with hair dryer replaced the plastic cover the second time. Still receive after couple of minute the F! sign. Please help.
i have the f1 but on both drawers but my neice did put some washing powder into it last nite
where is my chassis flood switch PCB on my DD-603
same as above
F1 fault on display
hi my dishdrawer keep going on f1 error how do i fix it, where is the flood switch?
how do i drain the water it is blocked
My top drawer was showing error F1 but the buttom drawer is working fine
same problem
have the same problem. now just the bottom drawer keeps alarming with F1. top drawer working. water accumulates in lower shelf below bottom drawer. do we need to change seals or something?
whan my system is start during the booting processit whan i press f1 then it boot what problem how can i shoot out it
Hi Both Draws show the F1 fault , the fault just comes on by its self.I have tried cutting the power but it still comes on.
same as above. F1 error on both drawers. managed to remove front of lower drawer, but could not access the pan. suggestions?
Thanks a bunch IDE man, I tried your way this morning and it worked perfectly, the pics were a BIG help!!
Thanks IDE man it worked perfectly, the pics were a BIG help!!!
double drawer dishwasher with F1 error when machine turned on
