Is there an interior emergency trunk release? if so, is there a way to
open the gas cap from inside the trunk?
Thanks so much, I can't put gas in the car.
Hi, yes there is. To release the trunk - look on the centre console, just rearward of the front seats and you will notice a separate rectangular section in the plastic, if you lift this out you will find a cable release for the trunk underneath. To open the fuel filler cap manually, look inside the car just behind the rear light on the same side as the fuel filler and you will notice a flap in the interior trim, which is to allow access to the rear lamp. Open this and then looking towards the top you should see a loop of orange plastic - pull this towards the rear of the car to release the fuel filler.
Hope that helps Matt..
