Color needs adjusting is there a chart for this
If the red,green and blue mixture adjustment is what you want...
remove front lower speaker grill & access panel..locate RGB
adjust on Screen / focus block.......slightly adjust screen controls for best mixture....do not adjust focus controls.....T.
Pull chassis,check soldered in micro-fuses,F851,F852,etc.
2)Usually,convergence IC's need replacement,if shorted.Check
it out and let me know.......T.
i see green with wavy white lines across the screen, does your answer still apply
it is green with wavy lines in it> does the answer still apply?
