When connecting the Dazzle Video Creator to the PC
When connecting the Dazzle Video Creator 100 to the PC I get a message that says it can not find a input-signal, please check the cable connections. I can´t see that its anything wrong with the connection.
Please install the Instant DVD Recorder 2.6.1
UPDATER if you are using the Dazzle DVD Video Recorder, Dazzle Video
Creator or Dazzle Video Creator Platinum with a previous version of
Instant DVD Recorder. This updater also includes the hardware drivers.
If you are using a Dazzle product already that includes
Instant DVD Recorder version 2.6.1, then you do not need to install this
update.
New with this version:
added support for Windows Vista 64 bit and Windows 7 (32 & 64 bit)(
Includes Windows Vista and Windows 7 drivers (for both 32 and 64 bit) for the DVC 100, 101, 103, 107 hardware NOTE: DVC130 and DVC170 don't have 64 bit drivers and can only be used with Windows XP and Windows Vista 32)
16x9 detection
PCM Audio (already included with Instant DVD Recorder ver. 2.5)
Supported Hardware:
Dazzle Video Recorder ( DVC90) - Windows XP and Vista 32 bit only
Dazzle Video Creator ( DVC130) - Windows XP and Vista 32 bit only
Dazzle Video Creator Platinum ( DVC170) - Windows XP and Vista 32 bit only
Dazzle Video Creator ( DVC100 and DVC101) - Windows XP 32 bit, Windows Vista and Windows 7 (32 bit and Vista 64 bit)
Dazzle Video Creator ( DVC103) - Windows XP 32 bit, Windows Vista and Windows 7 (32 bit and Vista 64 bit)
Dazzle Video Creator Platinum ( DVC107) Windows XP 32 bit, Windows Vista and Windows 7 (32 bit and Vista 64 bit)
and other compatible hardware
Installation Instruction:
To be able to install this version, you must own an Instant DVD Recorder Version 2.x full version
To install this Instant DVD Recorder version not as an
update but as a full version you need to enter your Instant DVD Recorder
Version 2.x serial number during the installation process. The serial
number was included in your Dazzle product.
With Windows Vista 64 bit or Windows 7 64 bit, you need to install Instant DVD recorder 2.6.1 as a full version.
If you own an Instant DVD Recorder Version 1.x full version, to only install Instant DVD Recorder 2.6.1 full version.
If you use this Instant DVD Recorder Updater to update
the Instant DVD Recorder included with Studio Version 12, 11 or 10,
please make sure that Instant DVD Recorder is already installed on you
system. Please note that the version of Instant DVD Recorder included
with Studio Version 12, 11 or 10 can't be installed under Windows Vista
64.
whatever you have your dazzle connected to must be turned on and receiving video... so if yo have it connected to a DVD player, the player has to be turned on and the error message will go away.
Welcome to Fixya,
What is the model of your dazzle device? Is taht DVC 100? if ever please check this procedure.
Step 1: Install the Pinnacle Dazzle Video Creator Platinum software and make sure it works with the Dazzle DVC 100. Sometimes this is easy, other times, this is a very difficult task. step 2: Buy 3 RCA type Y cables. One male end, 2 female ends.
Step 3: Plug the male ends of the RCA y-connectors to the Dazzle DVC 100.
Step 4: Plug the Yellow, Red and White RCA connectors from the XBox 360 to the color matched female RCA y-connectors on the Dazzle DVC 100.
Step 5: Plug a second triple RCA connector into the other end of the color matched RCA Y Connectors.
Step 6: Plug the other end of the triple RCA connector into the TV.
Step 7: The tricky part no one ever mentions: On the XBox 360 video cable, there is a switch that switches from HDTV to TV. You must switch this to TV!
I have something that can help you with, please checked if this is the same settings.
If you follow any of the videos, it won’t work!
Step 2: Buy 3 RCA type Y cables. One male end, 2 female ends.
Step 4: Plug the Yellow, Red and White RCA connectors from the PS3 to the color matched female RCA y-connectors on the Dazzle DVC 100.
