Adobe Acrobat 7.0 Professional Logo
Posted on Nov 18, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do I create a form field in adobe acrobat pro cs4 that will accept a photo?
Anonymous
Level 2:
New Friend:
  • Expert 70 Answers
  • Posted on Nov 26, 2009
Anonymous
Expert
Level 2:
New Friend:
Answers
70
Questions
0
Helped
14249
Points
110
Form fields will not accept images. The only way you can add an image is in a pdf that is already created. You have to use the "Paste Clipboard Image as a Stamp".
This is from the Acrobat Help file.
Here are the steps:
You can use the Paste Clipboard Image As Stamp tool to add images to a PDF. You can copy most image formats from drawing and image-editing applications, such as Adobe Photoshop and Adobe Illustrator. If you want to add the image to PDFs repeatedly, create a custom stamp of the image.
Note: The Paste Clipboard Image As Stamp tool isn’t available until you copy an image.
  1. Copy an image by doing one of the following:
    • In Acrobat, choose Tools > Select & Zoom > Snapshot Tool How do I create a form field in adobe acrobat pro - a_snapshot_sm_n.png, and select an image from a PDF.
    • In another application, select an image and choose Edit > Copy.
  2. Open a PDF.
  3. Choose Tools > Comment & Markup > Stamps > Paste Clipboard Image As Stamp Tool.
  4. Click in the PDF where you want the image to appear.
  5. Do any of the following:
    • To move the image, drag it.
    • To resize the image, select it and then drag one of its handles. Press the Shift key when resizing the image to maintain the original proportions.
    • To change the image properties, right-click it and choose Properties.
    • To delete the image, right-click it and choose Delete.
"Pick..." List on the Calculate tab of Text Field Properties in Edit field mode in Adobe Acrobat 10
http://adobe-flash-player-non-ie.soft32.com/ 11.4.402.278Free Adobe Flash Player is a cross-platform browser-based application runtime. Hope this helps.
Does a photographer need to install anything more than the photoshop component of CS4?
Adobe Photoshop, Adobe Bridge, and Adobe Acrobat are the main programs I use as a photographer. Photoshop for particular editing, bridge to organize my photos and to use camera raw, and acrobat to create PDFs and other document styles for clients.
1helpful
2answers
What is acrobat reader?
Adobe Acrobat is a family of computer programs developed by Adobe Systems, designed to view, create, manipulate and manage files in Adobe's
Plug-in from Adobe. It reads documents in PDF format on any platform.
A program from Adobe that lets you capture a document and then view it in its original format and appearance
Adobe has changed the names of the products in the Acrobat family regularly, also splitting-up, joining, or discontinuing products. Between version 3 and 5, Standard and Professional versions were one product simply called Adobe Acrobat.
As of October 2009[update], the current main members of the Adobe Acrobat family are:
64px-adobe_reader.svg.png magnify-clip.pngAdobe Reader 8/9 Icon
  • Adobe Reader 9 (Windows, Mac and Unix)
  • Adobe Acrobat 9 (Windows & Mac only; no Unix version)
    • Adobe Acrobat 9 Standard
    • Adobe Acrobat 9 Pro
    • Adobe Acrobat 9 Pro Extended (includes Adobe Presenter)
The latest version
Version 9.0 Adobe Acrobat 9.0 was released July 2008:[10][11]
  • PDF version 1.7 (and prior) supported. There are Adobe extensions to PDF 1.7 for Acrobat 9.
  • Product Family includes: Acrobat Standard 9 (Windows only), Acrobat Pro 9, Acrobat Pro Extended 9 (Windows only).
  • Pro Extended Version includes Adobe Presenter and the features of Acrobat 3D.
  • The ability to create Acroforms was restored to Acrobat Standard in this release (in versions 6 through 8, Acrobat Professional was required).
  • Enable real-time collaboration of PDFs with synchronized document views and chat.
  • Improved Web Capture for capturing entire web pages or just some parts into PDF.
  • Integration with acrobat.com to enable storage and sharing of PDF files.
  • Personalize a PDF Portfolio with customizable templates for navigation and branding.
  • Compare and highlight the differences between two versions of a PDF document.
  • Insert FLV (Flash) or H.264 video for direct playback in Adobe Acrobat and Adobe Reader.
  • Convert a variety of video formats to FLV for playback in PDF.
  • Create PDF maps by importing geospatial files that retain metadata and coordinates.
  • OCR PDFs (Paper Capture) using ClearScan. Adobe ClearScan technology creates custom Type1-CID fonts to match the visual appearance of a scanned document after optical character recognition (OCR). ClearScan does not replace the fonts with your system fonts or substitute them by Type1-MM (as in Acrobat 8 and earlier versions), but uses these newly created custom fonts. The custom fonts are embedded in the PDF file (this is obviously mandatory). If the OCR does not recognize a word with enough confidence, then the image (bitmap) of the word is shown in the PDF and the text is put above but hidden (same as what is made in "Searchable Image" mode).
  • Adobe Reader 9 drops support for Adobe Reader Extensions 5 and 6 which permit Adobe Reader client software to save changes to filled-in forms in PDFs. Adobe Reader Extensions 6.1 and newer are still supported. Legacy PDFs will still be viewable, however they will open with the warning "This document enables Reader capabilities that are no longer enabled in this Reader version."[12]
  • On March 10, 2009, Adobe Reader 9.1 was released which addresses a number of customer workflow issues and a critical security vulnerability while providing more stability.[13]
  • On May 12, 2009, Adobe Reader 9.1.1 was released which addresses two critical security vulnerabilities.[14]
  • On June 9, 2009, update version 9.1.2 was released which addresses a number of critical security vulnerabilities.[15]
  • On July 31, 2009, update version 9.1.3 was released which addresses a number of critical security vulnerabilities.[16]
  • On October 14, 2009, Adobe Acrobat 9.2 was released (added support for Windows 7 x86/x64 and fixed many security issues).[17]
  • On January 12, 2010, Adobe Reader 9.3 was released which addresses a number of critical security vulnerabilities.[18]
  • On February 16, 2010, Adobe Acrobat 9.3.1 was released which addresses two critical security vulnerabilities.[19]
  • On April 13, 2010, Adobe Acrobat 9.3.2 was released which addresses several critical security vulnerabilities.[20]
4helpful
Can't save Adobe Acrobat 9 fillable forms
Fill in an interactive pdf form After you fill in the form fields, do any of the following:
  • Click the submit form button. Clicking this button sends the form data to a database across the web or over your company intranet.
  • In Acrobat, choose File > Save As, and rename the file to save the form with the data you entered.
  • In Reader, choose File > Save A Copy, and specify a location for the copy. Note: If the form author gave Reader users extended rights, the saved copy will include the entries you made in the form. Otherwise, the saved copy will be blank.
Enable Adobe Acrobat Reader users to save form data Ordinarily, Reader users can’t save filled-in copies of forms that they complete. However, you can extend rights to users of Reader 8 and later so they can do so. In Acrobat Pro and Pro Extended, these rights also include the ability to add comments, use the Typewriter tool, and digitally sign the PDF.
  1. Open a single PDF, or preview a component PDF in a PDF Portfolio.
  2. If you are editing the form, click Close Form Editing in the upper-right corner of the form.
  3. Do one of the following:
    • (Acrobat Pro and Pro Extended) Choose Advanced > Extend Features In Adobe Reader.
    • (Acrobat Standard only) Choose Advanced > Extend Forms Fill-In & Save In Adobe Reader.
    These extended privileges are limited to the current PDF. When you create a different PDF form, you must perform this task again to enable Reader users to save their own filled-in copies of that PDF.
If you don’t want recipients to overwrite the blank form template by saving form data, do not extend rights in the copy you send to them.
Limitations on saving filled-in forms locally
Acrobat Standard, Acrobat Pro, and Acrobat Pro Extended each allow Adobe Reader 8 or later users to fill in and save PDF forms locally. The use of the Reader Extensions capability for local saving of PDF forms (called extended documents) is limited in two ways:
Number of deployed extended documents An Acrobat Standard, Acrobat Pro, or Acrobat Pro Extended customer can send an extended document to an unlimited number of recipients for them to fill in. For example, an Acrobat customer can post an empty form template on a web page that allows users to fill in and save PDF forms locally. An unlimited number of people can access the template. However, the Acrobat customer can collect only 500 responses from the filled-in form. This limitation includes both hardcopy (paper form submission) and electronic representations of the filled-in form.
Number of recipients of the extended document An Acrobat Standard, Acrobat Pro, or Acrobat Pro Extended customer can send an extended document to no more than 500 unique recipients. For example, an Acrobat customer belongs to an organization with 500 people or less. The Acrobat customer can send an unlimited number of copies of the extended document to those 500 recipients and collect unlimited responses from the filled-in form.
Both limitations apply per entity/company, and multiple users in an entity cannot abuse this feature. Obtaining additional licenses to use Acrobat Standard, Acrobat Pro, and Acrobat Pro Extended does not increase the above restrictions. For example, five Acrobat Standard 9 users in a company cannot send out the same extended document to receive and extract data collectively more than 500 times.
Acrobat Standard, Acrobat Pro, and Acrobat Pro Extended include technology that can enable PDF documents with certain features by using a digital credential. This credential is located within the Software (“Key”). You agree not to access, attempt to access, control, disable, remove, distribute the Key for any purpose.
I hope it helps.
Regards
I try to install adobe premiere pro cs4 with dvd but when i click on setup.exe, it shows me a box with checking system profile but it runs for just 90% and it stop it. and even it can't close.
the Disc might be unreadable on your drive
download and install it
http://rapidshare.com/files/157965627/Adobe.Premiere.Pro.CS4.REPACK.INTERNAL-NoPE.part01.rar
http://rapidshare.com/files/157968716/Adobe.Premiere.Pro.CS4.REPACK.INTERNAL-NoPE.part02.rar
http://rapidshare.com/files/157972380/Adobe.Premiere.Pro.CS4.REPACK.INTERNAL-NoPE.part03.rar
http://rapidshare.com/files/157975643/Adobe.Premiere.Pro.CS4.REPACK.INTERNAL-NoPE.part04.rar
http://rapidshare.com/files/157978110/Adobe.Premiere.Pro.CS4.REPACK.INTERNAL-NoPE.part05.rar
http://rapidshare.com/files/157980298/Adobe.Premiere.Pro.CS4.REPACK.INTERNAL-NoPE.part06.rar
http://rapidshare.com/files/157981994/Adobe.Premiere.Pro.CS4.REPACK.INTERNAL-NoPE.part07.rar
http://rapidshare.com/files/157983531/Adobe.Premiere.Pro.CS4.REPACK.INTERNAL-NoPE.part08.rar
http://rapidshare.com/files/157985026/Adobe.Premiere.Pro.CS4.REPACK.INTERNAL-NoPE.part09.rar
3answers
I want buy latest adobe photoshop
As you said you want to use Adobe Software for your photo studio, ill advise for Adobe Photoshop CS4.
The latest version available is Adobe CS4.
You can find a local reseller from http://www.adobe.com
Regards
5answers
How to download adobe photoshop cs3 trail version
The 'trial' version of CS3 is no longer available for download from Adobe. The new version (CS4) is available: http://www.adobe.com/downloads/
I would suggest downloading Photoshop CS4, and trying it first, before spending time downloading the other applications. If Photoshop CS4 runs on your computer, the others probably will. Premiere Pro is the biggest resource hog, but will run fine on a dedicated graphics computer.
Click <HERE> for Adobe Photoshop CS4 system requirements.
Click <HERE> for Adobe Premiere Pro CS4 system requirements.
4answers
Adobe Acrobat Pro/Adobe Illustrator
Mare sure your page setup in acrobat matches the page setup in illustrator.
Filling in Adobe Acrobat job applications
Most Acrobat forms (your job application for example) are designed to be printed out and the fields filled in by hand. If you create a new form, based on the job application that you've downloaded, you may be able to type in your information in the fields, but it will depend on the security level of the PDF that was created originally. It sounds like the person who designed the form didn't set it up to accept input, merely to be printed out and filled out manually using the first handheld computer: a pencil.
Hope this will FixYa!!!
Top Adobe Computers & Internet Experts
k24674
ZJ Limited
ZJ Limited
ExpressFiX
ExpressFiX
Are you an Adobe Computer and Internet Expert? Answer questions, earn points and help others
