Need advise on how to resolve this 108 printhead error problem
They mean the respective printheads have lost the HSynch. The first thing the we do (and have had great success with) is to clean the laser lenses. Then check the head wiring. The following codes apply:
106 & 110 CYAN
107 & 111 MAGENTA
108 & 112 YELLOW
109 & 113 BLACK
Clean the mirror on yellow, take out the toner cart. then locate the mirror towards the front end of the yellow printhead, don't touch with your hands, remove the mirror, clean with a rag return to it's location, if this does not work you will probably need a new printhead
Sounds like a fried laser to me!.....$400 for the part....if you can find it!
Make sure the printer is plugged straight into the wall and not through a surge device or power strip. Please try this even if the printer previously worked correctly with this surge device. Power strips and uninterrupted power supplies can cause a low amperage problem, which can trigger a false printhead error.
You may also want to try plugging the printer into a different wall outlet to see if the printhead error continues. This will eliminate the power source as a possible cause of the issue.
If still have the same issue a replacement of your printhead assembly is necessary.
For further assistance please contact Lexmark Technical Support.
Please
click on the link provided below.
If this
does not resolve the issue, please try to reseat the printhead cable.
This maybe caused by a system card failure or a defective printhead.
For further assistance, please contact Lexmark Technical Support Center.
Got the same problem....so let's get some help here?
I have lexmark c752l posted a printhead error 108, what its refer to?
117 printhead error
108 service printhead error
Anyone know exactly what this refers to... what can I expect to PAY to have the printer fixed?
Message d'erreur " Print Head Error"
