in run windows type services.msc and click ok it will open services window in services there are many windows services are there choose dcom server process launcher just double click on it will open dcom server process launcher properties in that go to recovery tab and in recovery choose the option first failure set to restart the service instead of restarting the computer set to all three option second and subsequent failure. And apply it. Have a nice day and do not forget to rate please...!
Just putthe cd windows xp to the rom drive and re-install the windows, be sure that your priority boot will be the cd rom then continue the installation and the system will repair your program.
That is an infections that doing that to your computer. You can stop the shutdown by running this command before the countdown reaches zero. Type this command from the Start->Run box:
shutdown -a
This should kill the countdown. However, you will have to get that infection removed from your computer.
Click on Start, then Run and then type command into the Run boxand then click OK. In the command prompt screen which appearstype shutdown -a and click Enter which will prevent yoursystem from shutting down. Then type exit in the command promptand click Enter which will close the application.
Once you have disabled MSBlast you need to protect your computer bydownloading a Microsoft patch so that your system will not remainvulnerable to MSBlast. Select your operating system below to download the relevant Windows patch.
Hold down Ctrl and Alt at the same time on your keyboard and press Delete with your other hand.On the dialog box which appears click Task Manager and then theselect the Processes tab along the top.
Click the Image Name column to organize the items alphabetically. Look forthe words MSBlast, Lovsan, Blaster, Teekids or MSLaugh. If you see anyof these click on the name so that itbecomes highlighted, then click End Process. Then close the Task Manager.
Click Start, then Search for any of the above-mentioned files onyour C: drive. If you do locate instances of such files delete them.
Reboot your computer and you can now reconnect to the Internet althoughit would be advised to install a firewall to protect yourself fromfurther threats. To find out more click here.
Here is a list of error codes for your unit: 12 Software bug. Contact dealer/factory. 13 Flash memory corrupted. Download new software. 14 Engineering only programming is complete. Call Christie, replace TIPM. 15 Attempting to download code without being in boot mode 16 Invalid interrupt. Power off/on. If it persists, contact dealer/factory. 17 Forced boot mode. Keys held down too long. 18 Attempting to program boot mode without jumper LAMP FAILURES 21 Lamp compartment too hot 25 Lamp 1 not installed 26 Lamp 1 Interlock: door open, lamp not installed 27 Unable to turn lamp 1 ON 28 Lamp 1 shut off unexpectedly 29 Lamp 1 driver overheated 2A Lamp 1 driver operation error (e.g. too hot can’t start) 2C Lamp 1 driver UART communications failure 30 Lamp 2 not installed 31 Lamp 2 door open 32 Unable to turn lamp 2 ON (unknown reason) 33 Lamp 2 shut off unexpectedly 34 Lamp 2 driver overheated 35 Lamp 2 driver reports operation error (e.g. too hot can’t start) 36 Lamp 2 driver UART communications failure 37 Lamp Watchdog Tripped – Unless lamps turn on again after 3 minutes, assume software hung.
