Are you getting sufficient power to the amp?
Could be a loose connection inside the amp (such as a wire), a bad component, or a severed ground. Many possibilities here. If you know electronics, take a multimeter and start testing all the components. Look for any burn marks, check for broken solder connections, and continuity test all wires. Be careful since amps can hold a deadly voltage for a good while. Be sure to drain the capacitors before doing anything else inside it. If you do not feel comfortable doing this, you can take it to a electronics repair person. Keep in mind that Crate is one of the harder amps to fix because most of their components are surface mount.
