My N95 Nokia phone which was only purchased 2 weeks ago from a Telstra Dealer now has a BLANK screen, phone still works as i can dial 101 messages but cannot see a thing on the screen!! I have tried switching the phone and off but the screen remains stubbornly blank. Any suggestions before i join the long queues at Telstra??
It must be a connection problem, to the LCD, or the light is not working.
Can only be sorted by looking at it really.
Back to Telstra I'm afraid. If it's new let them sort it out, if it's not try a reset take the sim card out first then input this code *#7780# (Best to use this code as a last resort)
Give it time to work.
It has restored the factory settings, but the problem's still there :( please help me, a screen comes for a while then it goes black
It has restored the factory settings but the problem's still there, please help me to fix it. Screen works for a few seconds then it goes black n doesn't work, can't see anything.
There's probably water vapour on the back of the LCD screen, same thing happen to me, just dry it our by holding a hair dryer to it. best to take the battery out though.
recently my phone(n95) screen started to flicker black whenever i slided it open, but then went back to normal and then like a couple of hours later the entire screen went black. I cant see anything. the backlights work and i can call and recive calls, but have no idea what numbers i type or who is calling. Any help would be appreciated.
I just had the same problem and i pressed *,3, and answer buttons at the same time on startup and it worked!!
People this is not the proble dont listen to these people if the screen was wrecked it would show a ranibow effect it is the ribbon cable connecting the phone to the screen these are and easy fix $30 and easy instalation i had the very same proble and i didnt touch mine i typed a text closed the screen and it died i changed the ribbon and its fine no.
Its the screen problem, u gtta purchase a brand new nokia n95 screen. that will sort the problem out properly.
My Nokia 95 got hit rather hard and the screen went black. The buttons still work but I can't see what they're doing. Is it completely stuffed or is there any way of sorting it out?
Thanks
For a repair guide and parts see http://www.formymobile.co.uk/n95disassembly.php
My n95 problum is when i on the swich then sho me the black screen so what is the saloshan this prob pliz tell me
Hi Dillan351, I read your post about the ribbon of the nokia n95 being the most common solution to the blank screen problem. I have one with that same problem and when i tested the screen on another nokian95 it worked fine, so can you please point me to how i can change the ribbon and which stores would sell it? Thanks in advance.
Hi Dillan351, I read your post about the ribbon of the nokian95 being the most common solution to the blank screen problem. I have one with that same problem and when i tested the screen on another nokian95 it worked fine, so can you please point me to how i can change the ribbon and which stores would sell it? Thanks in advance.
I had similar problem with blank display. Try this: Remove battery and Sim card and Memory data card. Replace battery and turn on phone. With my problem I then reset factory defaults. Then replace sim card and battery and turn on. You may have to choose on line mode when prompted. Cheers
I had same prob with my nokia 6120 which just kept getting blank screen or lines. I was writing an sms at the time. I fixed problem by updating the software/firmware from Nokia website. Back to normal yay!
Find your solution from the list,
Nokia N95
Codes:
Software & Hardware Problems
Find Solutions for other Nokia Phones:
Nokia N70
Nokia N73
Nokia 6300
Nokia 6600
All the other Nokia Phones.
Help!!!!
i got it wet and i have tried drying it but its still black screen or my picture on the screen is all muddled up. ive left it off for about 20mins and just turned it on and its saying test mode.
Good quality,free shipping,low prices
Jordan,AF1,Nike , RunningShoes, Sneakers, Dunks $40.(Credit card prepayment)
Brand Jeans: $ 38
Brand handbags: $38
Brand sunglasses, $18
Brand Caps/Hats: $ 18
Brand Belts: $ 28
Brand hoody,jacket,coat, $40
Years-reputation official online paradise , makes your life more beautiful.
http://www.cheapvogue.com/
Pls try here:t345131-nokia_n95_blank_screen
First of all u resold the ume ic then reball power ic your display should b working.from shahab rafiq from oman.+968998040094
hi, my n95 screen is black (but lights up) all my buttons light up but i cannot see a thing.... I can stil swithc it on and of ...
any suggestions??
Mine is doing the exact same thing right now ahhh!!!!
hi, when i turn on my nokia N95 the keypad lights switching on , but the screen light is off while i still see the display.
i got a permanent black screen while writing an sms
I purchased a new screen cover for my nokia N95. A few days ago I looked at my phone to only notice my screen and the buttons on the screen was not lighting up. I managed to look on my phone through the TV but still nothing for screen and buttons. Please help
x
my nokia screen is blank the lite still work but screen is blank
When i turn my cellphone on it lights up, but stays blank and i cant see anything, but when i connect the phone to my tv, everything is working but my screen on the cellphone is still blank.
What must i do?
my silver n95 has just gone blank, it still works i can call from it but cant see anything, most of my numbers are stored on the phone, so when i transfer the sim and memory card i dont have my numbers! so i tried hooking it upto nokia pc suite on my laptop to transfer everything off my phone but it says my phones in transfer mode and wont connect, how can i take it off transfer mode when i cant see what im doing! is there anyone out there who can talk me through it?
