I receive an error stating :
ACER ORBICAM APPLICATION HAS STOPPED WORKING
A problem caused the program to stop working correctly. windows will close the program notify you if a solution is available. Close Program.
I do not use messenger so it is not due to this being downloaded. There is nothing on the Acer troubleshooting and technical support to help with this.
Thanks!!
My Acer OrbiCam stopped working. I have an Aspire 5610-4491. What should I do?
There is a utility bar that you can install that lets you change the default application folder:
** Note ** When the My Pictures or Pictures folder gets full, camera will not work - Cut and Paste all pictures in that
folder to another folder and restart Orbicam program.
If that does not work then do this:
Start - Programs - look for Acer Empowering Technology then Acer E-Recovery - The look at the bottom and you will
"Backup", "Burn disk" and Restore" choose Restore - choose Apps and Drivers at the bottom of Restore tab (it will say
extracting) - once extracted - click Install - click Vista or (XP) on the left - click Drivers - click Camera or CCD - on the
right side of the screen, then look for Bison driver or (or your model which can be found in device manager - control panel - system - device manager - Imaging devices) you have then click a phrase that has something like "Install now", follow on screen instructions. Then repeat steps above and instead of driver choose Bison (or your model which can be found in device manager - control panel - system - device manager - Imaging devices) Utility
Comopn problem.. i have an acer aspre 1500 with the same orbicam.this same problem ocuured with me and i tried looking for a solution. as u said acer has no solution for this. suddenly a few weeks or months it worked back perfectly. if it doesnt come back on, go to problem reports and solutions, report it, see if theres a fix, if not try rebooting comp. and since its factory installed it shuld be back but reboot is a pain.
-regards
Sounds like youre using vista where live messenger starts up auto and tries to log you on whether you use it or not .if so let it run its course then right click on the icon and disable then reboot
SOURCE: Aspire 5610-2762 Orbicam not working
** Note ** When the My Pictures or Pictures folder gets full, camera will not work - Cut and Paste all pictures in that folder to another folder and restart Orbicam program.
Start - Programs - look for Acer Empowering Technology then Acer E-Recovery - The look at the bottom and you will "Backup", "Burn disk" and Restore" choose Restore - choose Apps and Drivers at the bottom of Restore tab (it will say extracting) - once extracted - click Install - click Vista or (XP) on the left - click Drivers - click Camera or CCD - on the right side of the screen, click a phrase that has something like "Install now", follow on screen instructions.
plz try by reloading the webcam software if you have webcam
same problem
