Horizontal line about 2 inches wide..multicolor lines...one white spot about 1.5 inches wide. Screen ok...plays dvd's ok.. In the old day's...I would look at the horizontal section .. Gee things have changed .. Thank You for your time..
My 3-year old 52-inch Toshiba flat panel TV (Model # 52RV53U, Serial # AM409000295) developed a display problem (purchased Aug. 2008, manufactured July 2008). Vertical multicolored lines appeared on the screen just left of center. The band of thin vertical bars is 5.5 inches wide. The lines are about 1/16-inch wide. They are stationary, always exactly in same place. They over-ride any other picture on the screen (no transparency). They are there all time even with no video inputs to the TV after the unit is turned on. See picture #1. The TV works well in every other respect, but, obviously, it is annoying to watch the picture with the color band blocking about 1/6 of the picture.
Further info, pics, comments, and updates on my Facebook page at
http://on.fb.me/mVwhVN
I already swapped out the TCON board with no improvement and replugged the TCON board cables with no improvement.
Most likely it is the flat panel tab bond failure (panel made by Samsung). Further solution updates will be on my Facebook page.
Check capicitor in vertical hold circuit. You should have solid knowledge of electronics repair before attemping repair. TV's can emmit harmful radiation, and produce voltages up to or in excess of 30kV.
Hi I had the same problem. Broken white lines across the top of the screen. This is called overscan. You need to go into the Setup menu, other settings. 16:9 overscan needs to be on. Hope this helps.It solved our problem.
Dirty heads or the recording was from a different brand VCR and the Panasonic cant get the right tracking. Try manual tracking just a little in either direction to you get the right one.
Open up the TV and unplug and re-plug the connectors to the circuit boards. This is most often caused by a poor connection of the circuit board connectors.
i have panasonic sophia tv 29" i have white horizontal line on middle of screen i know i have to solder ic but where is the ic located on main circuit board. thankx
