Pride New Mobility Legend 4 Wheel Scooter Logo
Anonymous Posted on Nov 16, 2009
Hi I have a shoprider cadiz .. when i try using
Hi I have a shoprider cadiz .. when i try using the levers to go forward or reverse there is many times no response .. or i will get an intermitant buzzing sound as if the reverse beeper is working .. many times when I stop the scooter will not go again or for some time .. have you any idea why please?
  • Anonymous Mar 24, 2014
    Hi I have a shoprider whisper. It run a little and then stops, if I turn it off and on again it runs a little and then get stuck again. Any ideas about what the problem is?
Anonymous
Level 1:
  • Contributor 29 Answers
  • Posted on Nov 20, 2009
Anonymous
Contributor
Level 1:
Answers
29
Questions
0
Helped
17104
Points
57
Your throttle pot needs replacing. your thumb lever attaches to the throttle pot.
Testimonial: "Wonderful information Thank you ..before i read your answer i sprayed the throttle pot as you call it with switch cleaner Been great since .. "
1helpful
I put motor back in shoprider cadiz & now wont go in gear watever way i move brake lever is there a paticular way to put back.
hi what type have you got , a coupler, a piece of plastic that sits between the motor and gearbox normally a white colour ?
regards
Rob
1helpful
Ihave shoprider cadiz and when i turn on it wont move just bleeps like it is out of gear but its not.
hi, make sure the freewheel lever engaged, so you can't move the scooter, turn it off and on, ?
Check the motor brushes making sure they can be removed easily if not that's the issue , refit them, taking care not to crack the brush caps.
Wig wag or called a throttle lever ,is it loose ? .
At worse it a controller fault ...
Regards
Rob
Gewizrepairs.co.uk
1helpful
1helpful
Why don't the turn signals flash on shoprider cadiz deluxe?
hi Vic, there a little black board under the tiller part , it got a ribbon cable to it so take care if looking at it , there's a fault with the circult..
Regard
Rob
Help me Help you ...
The forward/reverse lever on my shoprider cooper is loose. How can I repair it?
hi, you need to take the tiller apart and refit the spring ... this does happen, a picture will help and i can advise you what to do ...
Regards
Rob
www.gewizrepairs.co.uk
Top Pride Health & Beauty Experts
Rob Hill
Rob Hill
Mike Cairns
Mike Cairns
Grand Canyon Tech
Grand Canyon Tech
Are you a Pride Health and Beauty Expert? Answer questions, earn points and help others
