Hi, I was recently given a Samsung Syncmasster 2333sw flat screen monitor that I hooked up to my old Dell Dimension 8200 desktop.The monitor says the optimum resolution is 1920x1080 pixels. The maximum the...
hi bob
you should be able to adjust the screen size via the menu on the monitor itself, (Available in Analog mode only)
Note When TV signal is input in AV mode ,select “Screen Fit “to adjust
vertical position in 0-6 levels. Image Size Note
Supplied for the wide models only such as 16:9 or 16:10.
You can change the size of the screen displayed on your monitor.
PC signals • Auto - The screen is displayed in accordance with the screen aspect ratio of the input signals.• Wide - A full screen is displayed regardless of the screen aspect ratio of the input signals.
Note • Signals not available in the standard mode table are not supported.• If the wide screen which is the optimal resolution for the monitor is set on your PC, this function is not performed.
AV signals
• 4 : 3 - Sets the picture to 4:3 normal mode.
• 16 : 9- Sets the picture to 16:9 wide mode.
• Screen Fit- Use the function to see the full image without any cutoff
when DVI (480p/576p/720p/1080i/1080p) signals are input.
Note
It can only be selected if an external input is connected to the DVI
terminal and the 'PC/AV Mode' is set to 'AV'.
• Wide-Sets the picture to 16:10 wide mode.
Note
• It can only be selected if an external input is connected to the DVI
• When the panel is of 16:10,the screen size options include
“4:3”,”wide “,”Screen fit“.hope this helps
I don't think it's the cable. Do you have tips on tightening the loose jack?
thank you. I'll give it a try!
