Check your fuses first, when window motors get old they draw more power and can blow a fuse.
if your fuses are good then it's time to start taking the door pannle off.
If they all quit at the same time then you most likely have a blown fuse. If you dont have your manual you can use a flashlight to locate the burnt fuse. It should be fuse #14 which should be a 15amp fuse
For all types of power window problem and power windows not
working,i suggest you to go through the help links given below. Click the link
to go through its procedure to troubleshoot the problem :------
Power window problem
http://repairhelpcenter.blogspot.com/2012/01/pontiac-grand-am-power-window-not.html
Power windows not working after car wash?http://howtobyme.blogspot.com/2011/11/power-windows-not-working-after-car.html
power locks, power window and power mirror not working?
http://howtobyme.blogspot.com/2011/09/power-locks-power-window-and-power.html
All power windows not working?
http://howtobyme.blogspot.com/2011/09/all-power-windows-not-working-on-2003.html
How to remove window motor and regulator on Car?
http://howtobyme.blogspot.com/2011/09/how-to-remove-window-motor-and.html
Complete Diagnosis & Testing Power Windows?
http://repairhelpcenter.blogspot.in/2012/02/diagnosis-testing-power-windows.html
-----------This will help.Thanks
