I have a Sherwood R945RDS receiver with a wharfdale sUB woofer.
Problem is I cannot fugure out how to set the sub from off?
Can anyone please assist?
Regards
Leroy
Surround and subwoofer may not work if there is an additional graphic equaliser operating.
1. check in your receiver speaker setting ensure your speaker setup doesn not have subwoofer set to NONE. this will block any signal to your subwoofer socket.
2 when you select your surround sound setting setup, ensure you select the speaker mode you want, if there is a multicontrol knob, cycle through the choices
select subwoofer mode and set it to yes.
if you have set-up small speakers S in your speaker settings then it could be that subwoofer is set to yes automatically if you have large speakers L, subwoofer has to be set additionally in the subwoofer setting.
3 test subwoofer on alternative device to test it is working ok
consult manual on enjoying surround sound and adjusting the speaker settings.
My sub is powered on and connected but when pressing the speaker mode button, I can see that it is set to 'off' on the amp but not sure what to press to switch it to 'on'.
Thanks for the prompt reply.
Regards
Leroy
are you trying to get your sub on cause if its on and not playing then you have to go to your osd menu to change your sub seting to get it to come on and play
True, you have to change the sub setting in the on board display (osd). Check your owners manual and find out what you need to do to get to the speaker configuration page. Make sure the sun is set to "ON". Then loon on the back panel of your receiver and make sure your sub is connected to the "sub out" RCA plug outlet. If your receiver is 5.1, 7.1 and has analogue outputs be certain you do not have your sub cable plugged into the sub input for the analogue amp section, once set up correctly then check the back of your sub to make sure the phase and LEF effect switch is set correctly and the sub is turned on. Read your sub and reciever manual to make sure you have it right and turn on the set and see what you have.
*look *sub
