Janome Memory Craft 9000 Computerized Sewing Machine Logo
Anonymous Posted on Nov 16, 2009
Janome MC 9000 off touch screen calibration
To use menu selections on tiuch screen you have to touch to the left of the icon.
Machine just back from service never had this prob before
How can I adjust the position to the middle of the icon?
Thanks
Ian
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Nov 16, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
Helped
3155
Points
8
Thanks guys
I remembered the fix!!
On the Janome MC 9000
To calibrate the touch screen
1. Turn off
2. on Sewing arm above needle there are a series of buttons
3. Hold down bottom 3 buttons
4. While holding turn on machine
5. Using scribe
6. Touch the centre of each + as it appears
7. It will go Centre bottom rh centre top lh as you select each + position it moves of it's own accord.
8. Turn off machine
9 Turn on and test.
Important sometimes this does not entirely fix prob!!
Simply do it again "Yahoo""
Some mechanics will try to tell U the screen is on it's way out
Bollocks just calibrate.
Thanks
CYA
  • catherinekas Jul 17, 2011
    I had this same problem with my Janome 9000. The repair guy told me I needed a new mother board and something else too and that the parts alone would cost $900. He also said that labor would be $65 per hour.
    So, ok. I kept the machine but didn't repair it because I could still sew a straight stitch and the other 8 stitches that showed up on the first screen. I figured I could still use it until I saved enough to buy a new machine. I could not, however, get past the first screen. The turn the page icon simply would not work. I couldn't access the stitch length or width regulator page either.
    My daughter figured out that if you pushed the space to the right of the icon, you could make it do what you wanted. We found that we could, indeed, access all the pages and all the stitches just by pushing a little to the right of the icon even though there wasn't really much room to push in; especially where you turn the page and go to the next screen. There was what? a 16th of an inch?...you could only get a fingernail in there.
    Thanks so very much for your answer. I truly, truly appreciate it. You have saved me about a thousand dollars. Your recalibration fix worked and the machine is perfect once again.
  • Denise Jan 31, 2021
    How do you go back to the prior screen?
Hassy
Level 3:
  • Janome Master 1,388 Answers
  • Posted on Apr 12, 2010
Hassy
Janome Master
Level 3:
Answers
1388
Questions
Helped
496001
Points
2943
Best to do the reset routine 3 times.
For some reason it can take this many to actually complete the re-calibration successfully
Bargain Box
Anonymous
Level 1:
New Friend:
  • Posted on Aug 18, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
3155
Points
The touch screen wont work on my MC 9000. The power is there but the screen just wont work. Any help would be great
Thanks
Jenni
2answers
Non responsive touch screen janome mc 9000
can you not take or send the machine back, you say you just bought it?
2helpful
2answers
I'm told i need a new touch screen for my memory craft 8000 what would it cost the place i took it to didn't know for sure?
Try this link for an affordable solution to repairing your Janome MC 8000 Display Back Light.
https://sew-bright.com/products/janome-memory-craft-8000-lcd-backlight-replacement-kit
1helpful
2answers
Display problem
Hi Wendy,
If you care to email me I can send the MC 9000 screen reset details as a first step to identifying the problem.
Please remember to specify what you are requesting as there is no direct link from this site and we receive many requests each day.
Use the Contact Us form at the site linked below
Cheers
Martyn
Bargain Box
3helpful
The icons are out of sync.
Have a sewing machine needle handy and turn the machine off.
With your left hand, press and hold /StartStop, Up/Down and reverse while switching on the machine. The screen should display little cross hairs. Using the BLUNT end of the needle NOT THE TIP, press the exact center of the cross hairs. Continue a the cross hairs will change positions on the screen. When finished, switch machine off, wait five seconds and switch back on.
I have a Janome MC9000. The touch screen is out of sync with the icon. I purchased on eBay so no dealer will touch it. Only one function on the extreme right hand (the instruction panel) works (the menu...
If you would like instructions on How To Reset the Touchscreen for the MC 9000 (or other model Janome) so that the icons re-align, please use the link below to contact me and just make sure to mention the specific request and model number (we get a LOT of mail).
Same Reset offer applies for other Janome Touchscreens, and we even even have a replacement LCD Backlight for any MC 8000 or MC 5700 that is growing dim.
Bargainbox.com.au
6helpful
3answers
You need to adjust the screen. Turn the machine off. Press simultaneously the three buttons on the front (Start, reverse and stop) at the same time turn the machine on.
Press the crosses that appear on the screen and it should all be fine.
4helpful
3answers
The sewing advisor screen on a Janome 8000 is getting dim.
When your Memory Craft 8000 or MC 5700 is otherwise working fine but the LCD display screen begins to grow darker and you find you just can't read it, the only thing you can do is replace the LCD screen, or buy a new machine.
Janome no longer stock this item direct, but there is an affordable replacement available.
Full Access and Installation instructions are provided, so you can DIY or have someone else do the replacement for you.
Check this Link
Also includes advice, links & contacts to be able to Reset your screen and do a Self Diagnosis Routine to test your machine BEFORE you purchase a replacement LCD backlight for either the Janome MC 8000 or MC 5700, so you can check that there are no other troubles.
Top Janome Sewing Machines Experts
ZJ Limited
ZJ Limited
Kolbrun...
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
