Samsung AS18A6RB Air Conditioner Logo
Posted on Nov 16, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I start my as 12 samsung ac with the remote or
I start my as 12 samsung ac with the remote or directly on the unit,but get only the beep noise an leds ars flashing,all this started with code 00 on the remote control
Anonymous
Level 2:
  • Expert 400 Answers
  • Posted on Nov 18, 2009
Anonymous
Expert
Level 2:
Answers
400
Questions
0
Helped
225156
Points
937
If you look carefully at the remote there is a reset button, try resetting it and make sure you have new batteries.
My lg split ac non inverter is working fine but missing command beep
  1. Check the remote control: Look for a button on your remote control labeled "Beep" or "Sound". Press this button to turn the beep sound back on .
  2. Check the settings: If you can't find a "Beep" or "Sound" button on your remote control, check the settings menu on your AC unit. Look for an option to turn the beep sound on or off and make sure it's turned on .
  3. Reset the AC unit: If neither of these steps work, try resetting your AC unit to its factory default settings. To do this, turn off the AC unit and unplug it from the power outlet. Wait for a few minutes and then plug it back in and turn it on .
If none of these steps work, it's best to contact a professional or LG's service center for further assistance.
I hope this helps!
2helpful
2answers
How do I turn off the beep of the remote?
I will tell u the exact answer, press the 2nd F button and agin press the beep off button and do same for on off beep. It will on and off ur beep of remote.
Our remote control will not work with our Dometic Model 57915 unit. It used to when you changed the temperature up or down you got a beep from the unit. When you push the on/off button, it used to beep...
The comfort control center requires 12 VDC . If a fuse blew that feeds 12 VDC to control box at ceiling for some reason in your panel when unplugged accidentally, that would cause the remote/wall and control box at ceiling not to communicate.
MY SAMSUNG SPILT AC 1 1/2 TONS SLIVER NANO TECHNOLOGHY TYPE IS NOT RESPONDING AND A GREEN LIGHT ALONG THE I HR SYMBOL IS FLASHING ..! WHAT DO I DO?
It means, someone set the timer to start the unit after one hour. To cancel, simple remove battery from remote and reset it. And also power of the unit and reset it. Now start your unit with remote.
12helpful
2answers
On ac with out remote
Lift the front panel on the indoor unit and press the small button on the right hand side near the electrical cover
1helpful
2answers
Dark screen samsung syncmaster 920 N strange noise behind it
The clicking sound you hear is the power supply board trying to start up, this indicates the board has failed. This is a common problem with all LCD monitors after a few years of use. Parts called capacitors on the power supply board fail and they will keep the power supply from starting up correctly. If you can solder then you can repair the board yourself. Here is a link to a repair guide with pictures and videos showing how to dis-assemble the unit and then what to look for and replace to rebuild the board and get the unit back running.
http://www.ccl-la.com/blog/index.php/repairing-the-samsung-920n-920nw-monitors/
I hope this helps, if so please rate my solution.
BuddyMc
16helpful
2answers
SAMSUNG split AC AS09WHWE led keeps blinking.
Samsung Air Conditioners SAMSUNG split AC AS09WHWE led keeps blinking
2answers
Samsung 1.5 ton slpit AC.the out door unit is very noisy
Check to see if the noise is coming from the fan, could be bad bearings. Replace the fan motor if that is the case. If the noise is coming from the compressor, the only other place besides the fan, then your compressor has some issues and will probably stop working soon, maybe line up for a replacement before you are left with a hot house.
2helpful
Central air condtioner making beeping noise!
it means it has a fault. try resetting unit by switching circuit breaker off and on it might go away
Top Samsung Heating & Cooling Experts
jws1013
Are you a Samsung Heating and Cooling Expert? Answer questions, earn points and help others
