Sharp R-1510 Start Button Not Working
This may not solve your problem, but on my Sharp R315J microwave, the little plastic pin that pushes forward on the inside of the start button, had broken off and it wouldn't start. The Minute Plus button would start the microwave, so I knew the microwave worked, so I tried to find a piece of plastic that I could glue into the start button hole, because the part doesn't exist and you have to buy the whole door for $100 plus shipping. Nothing I could find was small enough, so I started looking for a new microwave.
While ouside doing lawn work I noticed a small bird tail feather and the end looked to be the perfect size. I snipped off the pointed end and then up about 3/8" to make a little rod to replace the plastic one that broke. It fit perfectly!!! I didn't even have to glue the inside end, it stays put even after repeated door opens. This is sturdy material and looks to last a long time. When it wears out, I have a cat, there's always a few feathers around. I hope this saves someone else a hundred bucks, like it did me.
The ovens clock and function buttons work but the start botton does not work.
my microwave is not working good, start button is not working, and some times when i powered off and re-connect after a week. it is working for 2or 3 times. and again same problem is repeating. remaining buttons are working are good. can you help me, how can i repair that. mine is sanyo
Thanks
rnr
My start button does not work. The turntable turns continually, even after stop is pushed. Unbelievably, Electrolux provides no technical support.
Dacor pcor30s
I had a water leak from above and now my buttons do not work, the display above works but no response from any buttons.
Samsung microwave start button does nothing...light inside remains on. I had removed the glass turntable to clean it, replaced it correctly. Then, the start issue. Any suggestions?
Please reply back to this with your brand and full model number.
